Hallo everybody,
we recently have changed DevExpress for Infragistics and got a problem with our shp-files: they will not be displayed in Siverlight. The samples that come along with Infragistics 9.2 look like to have a different format. I will be appreciative for any suggestion, how to convert our dxf -file to shp-format conform with Infragistics 9.2.
Thanx,
Anna
we will investigate issues with any shapefile you provide. if you look at the "options" tab when composing a message on this forum, there is a way to attach a file.
Can I send you the shape files we use? I have the same problem taht the map will not show on using 9.2. I can see the map in ESRI ArcMap.
James
Can you post the shp file here (attach it to a forum post), or email it to me (devinr@infragistics.com). I can have one of the developers take a look at it and see if there is an issue with the Map.
Devin
Thank you, Devin,
we also use this software for dxf2shp convertion, it evidently must be another point interfering to get the shp-file correctly shown in Siliverlight.We'll keep on trying...
I've used this utility in the past to convert AutoCAD format files to shp format:
http://www.wanderingidea.com/content/view/12/25/
