870
Handling CRUD Errors with an SQL Data Source
I have followed the directions in the help item titled: "Handling CRUD Errors with an SQL Data Source" in the 2009.2 online documentation and have the following problems:
1) When a database error occurs, the grid does not restore to the original values even though the click event handler for the OK button in the dialog does fire and is run successfully.
2) Once an error has been traded once, any attempt at updating a value in the grid causes an exception to be thrown by the IG controls and no updates are posted:
Server Error in '/' Application.
Index was outside the bounds of the array.
Description: An unhandled exception occurred during the execution of the current web request. Please review the stack trace for more information about the error and where it originated in the code.
Exception Details: System.IndexOutOfRangeException: Index was outside the bounds of the array.
Source Error:
An unhandled exception was generated during the execution of the current web request. Information regarding the origin and location of the exception can be identified using the exception stack trace below.
Stack Trace:
[IndexOutOfRangeException: Index was outside the bounds of the array.]
   Infragistics.Web.UI.LayoutControls.DialogWindowBot.LoadClientObjects(Object[] objects) +71
   Infragistics.Web.UI.Framework.ObjectBase.LoadClientState(Object[] oData) +202
   Infragistics.Web.UI.Framework.RunBot.HandleOnInit(HttpContext context) +294
   Infragistics.Web.UI.Framework.ControlMain.OnInit(EventArgs e) +158
   System.Web.UI.Control.InitRecursive(Control namingContainer) +333
   System.Web.UI.Control.InitRecursive(Control namingContainer) +210
   System.Web.UI.Page.ProcessRequestMain(Boolean includeStagesBeforeAsyncPoint, Boolean includeStagesAfterAsyncPoint) +378
Client side code is:
nbsp;   <script type="text/javascript" id="igClientScript"><!--
function Button3_onclick() {
    var dialog = $find("WebDialogWindow1");
    var grid = igtbl_getGridById("UltraWebGrid1");
    grid.Rows.refresh();
    dialog.hide();
function UltraWebGrid1_XmlHTTPResponseHandler(gridName, rowId, gridResponse){
    var xmlResponseObject = gridResponse;
    var grid = igtbl_getGridById(gridName);
    if (xmlResponseObject.ReqType == igtbl_reqType.UpdateRow ||
        xmlResponseObject.ReqType == igtbl_reqType.AddNewRow ||
        xmlResponseObject.ReqType == igtbl_reqType.DeleteRow
        if (xmlResponseObject.ResponseStatus == 1) {
            var contentDiv = document.getElementById("ErrorDiv");
            contentDiv.innerHTML = xmlResponseObject.StatusMessage;
            dialog.show();
Server Side Code:
    Private Sub HandleError(ByVal e As SqlDataSourceStatusEventArgs)
        If e.Exception IsNot Nothing Then
            ' This information is available during the client side
            ' UltraWebGrid1_XmlHTTPResponseHandler event
            ' Set response status so client will know the status of update
            Me.UltraWebGrid1.ClientResponse.ResponseStatus = XmlHTTPResponseStatus.Fail
            ' The exception detail
            Me.UltraWebGrid1.ClientResponse.StatusMessage = e.Exception.Message
            ' The custom message for the client can be stored in the tag of the response
            Me.UltraWebGrid1.ClientResponse.Tag = _
            "Update was not successful, check exception details for further information"
            e.ExceptionHandled = True
        Else
            Me.UltraWebGrid1.ClientResponse.Tag = "The process worked"
        End If
    End Sub
    Private Sub SqlDataSource1_Deleted(ByVal sender As Object, ByVal e As System.Web.UI.WebControls.SqlDataSourceStatusEventArgs) Handles SqlDataSource1.Deleted
        HandleError(e)
    End Sub
    Private Sub SqlDataSource1_Inserted(ByVal sender As Object, ByVal e As System.Web.UI.WebControls.SqlDataSourceStatusEventArgs) Handles SqlDataSource1.Inserted
        HandleError(e)
    End Sub
    Private Sub SqlDataSource1_Updated(ByVal sender As Object, ByVal e As System.Web.UI.WebControls.SqlDataSourceStatusEventArgs) Handles SqlDataSource1.Updated
        HandleError(e)
    End
Any help would be appreciated,
Dana
