175
How to get value from textbox in celltemplate
I added a template column to my grid so users can type in a value. In the cell template i put an asp.net textbox. What i want to do is on postback loop through the grid rows and if the user had entered something in the textbox save that information.
I can't figure out how to access the textbox data though. The templated cell in my ultragridrow is showing null. Any help appreciated.
<igtbl:TemplatedColumn Width="180">
                                    <Header Caption="Enter Value">
                                        <RowLayoutColumnInfo OriginX="5" />
                                    </Header>
                                    <CellTemplate>
                                        <asp:TextBox ID="txtNote" runat="server" Width="170"></asp:TextBox>
                                    </CellTemplate>
                                    <Footer>
                                    </Footer>
                                </igtbl:TemplatedColumn>
  • 175
    Verified Answer
    Nevermind figured it out finally with the help of this post:
    http://community.infragistics.com/forums/p/27385/100983.aspx#100983
    Added a key to my template column and used below code.
    foreach (UltraGridRow r in grid.Rows)
                TemplatedColumn t = (TemplatedColumn)r.Cells.FromKey("UserInput").Column;
                CellItem c = (CellItem)t.CellItems[0];
                TextBox x = (TextBox)c.FindControl("txtNote");
                if (!string.IsNullOrEmpty(x.Text))
                    test = int.Parse(r.Cells[2].Value.ToString());
