1060
IE8 - column header width don't match main
Using UltraWebGrid 9.2 (latest release) on ASP.Net 3.5 - if I force IE8 into proper 'IE8' mode (i.e. not compatibility mode) then my column headings go more and more out of alignment - although this isn't a problem in compat. mode or on IE7 or Firefox.
Any suggestions as to things to try - it won't be easy to pull out a sample project, so I'm after some suggestions first if possible.  I have tried different 'themes' but they do the same (as I'm using a customises version of the Office2007Blue theme - so I did want to double check it wasn't my theme somehow breaking it).
Hopefully you can see in the example below...the columns get more and more out of alignment.
btw I did see a post suggesting adding this:
<RowStyleDefault>
       <Padding Left="0px" />
</RowStyleDefault>
but that had no affect...
