i am using ultra webtab with 5 tabs ,its working fine.when i am using global asax page the webtab is not responding,it does not throw any error but it does not let me to select any tab.I am not using any java script.I am using only vb.net.If anyone know the solution , please reply.Thanks in Advance
I believe this problem and the symptoms described are very similar to the problems described in this forum thread (using UltaWebMenu with global.asax). Maybe some of the suggestions in the forum thread on this topic will be applicable in this case as well:
http://forums.infragistics.com/forums/t/3284.aspx
Hope this helps.
