We have migrated our application from .NET 1.1, Infragistics 5.1 to .NET 3.0 and Infragistics 8.2.
We have an issue with the ‘NextMonthText’ and ‘PrevMonthText’ in webdatechooser.
Both have been set to ‘>’ and ‘<’ respectively, but both of them appear painted fully (solid triangles) in UI after migration.
This was not happening before migration.
We have also tried setting ‘NextMonthImageURL’ and ‘PrevMonthImageURL’ by including the images in the project directory. This works fine for IE7, but for IE6 the images appear with a background color.
Please find the attached document for screen shots and detailed description.
We need to display it in the same way as it was displayed before migration.
Please suggest a fix.
Thanks in advance...
Please see the image below.
It says that some browsers paint a triangle in the NextMonthText
Can you perhaps provide a sample Visual Studio 2005/2008 project ?
I understand your problem and I honestly hope someone will provide a workaround for IE6
However if you can't find any workaround then I can suggest to tell your boss to dump IE6 and look into the future.
