525
AddNewRowCell in CellExitedEditMode
I'm having some problems retrieving the value of a cell in the CellExitedEditMode event using the AddNewRowFeature.
Value's of a cell that have a column which key is linked to a field in my business object on the first level are retrieved correctly (eg executorFullName below, e.Cell.Value contains a string)
     <igGrid:TextColumn IsSortable="False" IsFixed="Left" HeaderText="Executor" Key="executorFullName" />
However: values's of a cell that have a column which key is linked to a fied in my business object on the second level are not retrieved correctly (it is null)
<igGrid:TextColumn IsSortable="False" IsFixed="Left" HeaderText="Home Base" Key="oHomeBase.description" />
e.Cell.Value of oHomeBase.description is null.
Regular editing of existing records on my grid works perfectly. The above scenario only occurs when using AddNewRow.
