85
Getting Column Properties from the UltraWebGrid
What i'm looking for is how to get certain column properties back from the grid - in order to save user preferences for Ordering, Grouping and Sorting each time a user loads a particular Grid. I've listed below what i've found that may be useful - but i'm very new to the Infra Grid, and am thinking there are better methods available.
 If it's possible, i'd like to just grab a listing of all Column Titles that are grouped, all that are sorted and the orders of each column. If I can't do that without going through each column in the grid - that's ok but if there's an alternative it would be a lot faster.
Sort;
UltraWebGrid1.Columns.Item(0).SortIndicator.ToString() - this just tells me that the column is descending, or Ascending - is there a better method? I also don't know which Sort should be done first using this method?
Grouping;
UltraWebGrid1.Columns.Item(0).IsGroupByColumn.ToString() - again - I can find out if a Column is grouped - but is there a property that tells me what level of Grouping this column is? I could have two or three columns grouped with no way of knowing where they sit.
Ordering;
Is there a method showing the order of columns besides the Column index? i.e. if a user moves a column three places to the right - I'd like to save that column
 I appreciate any help that is available
  • 21382
     Off the Grid, DisplayLayout, or Band object (I forget which one), is a SortedColumns collection.  This will give you the Sorted Columns and GroupBy columns (since group by is just a sort).  Go through this collection, checking the sort indicator and isgroupby for each column.  They are in the collection in the order that they are applied.
    As for order, I think the index is the only way of knowing, but I don't have a webgrid infront of me to verify it.
