Environment:
App Server: JBoss 5.1.0.GA
JDK: 1.6
JSF: 1.2
Exception Details:
2009-11-25 14:35:59,997 INFO [javax.enterprise.resource.webcontainer.jsf.config] (main) Initializing Mojarra (1.2_12-b01-FCS) for context ''2009-11-25 14:36:00,262 ERROR [org.apache.catalina.core.ContainerBase.[jboss.web].[localhost].[/]] (main) Exception sending context initialized event to listener instance of class org.jboss.web.jsf.integration.config.JBossJSFConfigureListenercom.sun.faces.config.ConfigurationException: CONFIGURATION FAILED! Source Document: vfszip:/C:/jboss-5.1.0.GA/server/pv/lib/infragistics-shared.jar/META-INF/faces-config.xml Cause: Class 'com.infragistics.faces.shared.smartrefresh.SmartRefreshInitializer' is not an instance of 'interface javax.faces.event.PhaseListener' at com.sun.faces.config.ConfigManager.initialize(ConfigManager.java:213) at com.sun.faces.config.ConfigureListener.contextInitialized(ConfigureListener.java:196) at org.jboss.web.jsf.integration.config.JBossJSFConfigureListener.contextInitialized(JBossJSFConfigureListener.java:60) at org.apache.catalina.core.StandardContext.listenerStart(StandardContext.java:3910) at org.apache.catalina.core.StandardContext.start(StandardContext.java:4393) at org.jboss.web.tomcat.service.deployers.TomcatDeployment.performDeployInternal(TomcatDeployment.java:310) at org.jboss.web.tomcat.service.deployers.TomcatDeployment.performDeploy(TomcatDeployment.java:142) at org.jboss.web.deployers.AbstractWarDeployment.start(AbstractWarDeployment.java:461) at org.jboss.web.deployers.WebModule.startModule(WebModule.java:118) at org.jboss.web.deployers.WebModule.start(WebModule.java:97) at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method) at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:39) at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:25) at java.lang.reflect.Method.invoke(Method.java:597) at org.jboss.mx.interceptor.ReflectedDispatcher.invoke(ReflectedDispatcher.java:157) at org.jboss.mx.server.Invocation.dispatch(Invocation.java:96) at org.jboss.mx.server.Invocation.invoke(Invocation.java:88) at org.jboss.mx.server.AbstractMBeanInvoker.invoke(AbstractMBeanInvoker.java:264) at org.jboss.mx.server.MBeanServerImpl.invoke(MBeanServerImpl.java:668) at org.jboss.system.microcontainer.ServiceProxy.invoke(ServiceProxy.java:206) at $Proxy38.start(Unknown Source) at org.jboss.system.microcontainer.StartStopLifecycleAction.installAction(StartStopLifecycleAction.java:42) at org.jboss.system.microcontainer.StartStopLifecycleAction.installAction(StartStopLifecycleAction.java:37) at org.jboss.dependency.plugins.action.SimpleControllerContextAction.simpleInstallAction(SimpleControllerContextAction.java:62) at org.jboss.dependency.plugins.action.AccessControllerContextAction.install(AccessControllerContextAction.java:71) at org.jboss.dependency.plugins.AbstractControllerContextActions.install(AbstractControllerContextActions.java:51) at org.jboss.dependency.plugins.AbstractControllerContext.install(AbstractControllerContext.java:348) at org.jboss.system.microcontainer.ServiceControllerContext.install(ServiceControllerContext.java:286) at org.jboss.dependency.plugins.AbstractController.install(AbstractController.java:1631) at org.jboss.dependency.plugins.AbstractController.incrementState(AbstractController.java:934) at org.jboss.dependency.plugins.AbstractController.resolveContexts(AbstractController.java:1082) at org.jboss.dependency.plugins.AbstractController.resolveContexts(AbstractController.java:984) at org.jboss.dependency.plugins.AbstractController.change(AbstractController.java:822) at org.jboss.dependency.plugins.AbstractController.change(AbstractController.java:553) at org.jboss.system.ServiceController.doChange(ServiceController.java:688) at org.jboss.system.ServiceController.start(ServiceController.java:460) at org.jboss.system.deployers.ServiceDeployer.start(ServiceDeployer.java:163) at org.jboss.system.deployers.ServiceDeployer.deploy(ServiceDeployer.java:99) at org.jboss.system.deployers.ServiceDeployer.deploy(ServiceDeployer.java:46) at org.jboss.deployers.spi.deployer.helpers.AbstractSimpleRealDeployer.internalDeploy(AbstractSimpleRealDeployer.java:62) at org.jboss.deployers.spi.deployer.helpers.AbstractRealDeployer.deploy(AbstractRealDeployer.java:50) at org.jboss.deployers.plugins.deployers.DeployerWrapper.deploy(DeployerWrapper.java:171) at org.jboss.deployers.plugins.deployers.DeployersImpl.doDeploy(DeployersImpl.java:1439) at org.jboss.deployers.plugins.deployers.DeployersImpl.doInstallParentFirst(DeployersImpl.java:1157) at org.jboss.deployers.plugins.deployers.DeployersImpl.doInstallParentFirst(DeployersImpl.java:1178) at org.jboss.deployers.plugins.deployers.DeployersImpl.doInstallParentFirst(DeployersImpl.java:1210) at org.jboss.deployers.plugins.deployers.DeployersImpl.install(DeployersImpl.java:1098) at org.jboss.dependency.plugins.AbstractControllerContext.install(AbstractControllerContext.java:348) at org.jboss.dependency.plugins.AbstractController.install(AbstractController.java:1631) at org.jboss.dependency.plugins.AbstractController.incrementState(AbstractController.java:934) at org.jboss.dependency.plugins.AbstractController.resolveContexts(AbstractController.java:1082) at org.jboss.dependency.plugins.AbstractController.resolveContexts(AbstractController.java:984) at org.jboss.dependency.plugins.AbstractController.change(AbstractController.java:822) at org.jboss.dependency.plugins.AbstractController.change(AbstractController.java:553) at org.jboss.deployers.plugins.deployers.DeployersImpl.process(DeployersImpl.java:781) at org.jboss.deployers.plugins.main.MainDeployerImpl.process(MainDeployerImpl.java:702) at org.jboss.system.server.profileservice.repository.MainDeployerAdapter.process(MainDeployerAdapter.java:117) at org.jboss.system.server.profileservice.repository.ProfileDeployAction.install(ProfileDeployAction.java:70) at org.jboss.system.server.profileservice.repository.AbstractProfileAction.install(AbstractProfileAction.java:53) at org.jboss.system.server.profileservice.repository.AbstractProfileService.install(AbstractProfileService.java:361) at org.jboss.dependency.plugins.AbstractControllerContext.install(AbstractControllerContext.java:348) at org.jboss.dependency.plugins.AbstractController.install(AbstractController.java:1631) at org.jboss.dependency.plugins.AbstractController.incrementState(AbstractController.java:934) at org.jboss.dependency.plugins.AbstractController.resolveContexts(AbstractController.java:1082) at org.jboss.dependency.plugins.AbstractController.resolveContexts(AbstractController.java:984) at org.jboss.dependency.plugins.AbstractController.change(AbstractController.java:822) at org.jboss.dependency.plugins.AbstractController.change(AbstractController.java:553) at org.jboss.system.server.profileservice.repository.AbstractProfileService.activateProfile(AbstractProfileService.java:306) at org.jboss.system.server.profileservice.ProfileServiceBootstrap.start(ProfileServiceBootstrap.java:271) at org.jboss.bootstrap.AbstractServerImpl.start(AbstractServerImpl.java:461) at org.jboss.Main.boot(Main.java:221) at org.jboss.Main$1.run(Main.java:556) at java.lang.Thread.run(Thread.java:619)Caused by: com.sun.faces.config.ConfigurationException: Source Document: vfszip:/C:/jboss-5.1.0.GA/server/pv/lib/infragistics-shared.jar/META-INF/faces-config.xml Cause: Class 'com.infragistics.faces.shared.smartrefresh.SmartRefreshInitializer' is not an instance of 'interface javax.faces.event.PhaseListener' at com.sun.faces.config.processor.AbstractConfigProcessor.createInstance(AbstractConfigProcessor.java:259) at com.sun.faces.config.processor.LifecycleConfigProcessor.addPhaseListeners(LifecycleConfigProcessor.java:141) at com.sun.faces.config.processor.LifecycleConfigProcessor.process(LifecycleConfigProcessor.java:114) at com.sun.faces.config.processor.AbstractConfigProcessor.invokeNext(AbstractConfigProcessor.java:108) at com.sun.faces.config.processor.FactoryConfigProcessor.process(FactoryConfigProcessor.java:132) at com.sun.faces.config.ConfigManager.initialize(ConfigManager.java:203)
