540
How to cooperate webgrid server side function with AJAX function
Hello:
     I adopt Netadvantage Asp.Net 2009 V2 and I want my webgrid to accomplish below function:
1. add new row in the grid.
2. Check the new row data is correct or not ? if it was not correct therefore the grid would not allow to add new row.
3.  view the grid with paging function.
Originally I complete first item by enable DisplayLayout "AddNewRow function" and put the grid in a updatepanel to achieve ajax function.
I also follow the help manual section "Using XML Load -On -Demand " to view the grid with paging function. But I found that after I complete the paging function by waye of the help manual's suggestion the original  "AddNewRow function"  did not work anymore.
My problem is as below:
1. Did it mean I can not use updatepanel and grid "XML Load -On -Demand " together?
2. How to remove the new row added in the grid by way of "AddNewRow function" as soon as I found the row data violate regulation.
Any suggestion is welcome.
Sincerely,
     Daniel Lee
