525
IsOnCellActiveEditingEnabled
I set IsOnCellActiveEditingEnabled="True" to make sure that when I fill in data in a XamWebGrid and use the Tab key to navigate to other cells, that the selected active cell is automatically in edit mode. (as illustrated below)
However, another requirement for my grid is that is must be enabled to select multiple cells using shift key, ctrl key or just using the mousebutton. It is logical (I guess) to set IsOnCellActiveEditingEnabled="False" to enable this (as Illustrated below). If I leave the setting to "True", the first cell is in edit mode and I can't select other cells without leaving edit mode.
Is there a possibility to combine the "True"/"False" flag and what would be the best way/events to achieve such functionality ?
Nicolas
Parents Reply Children
No Data
