100
Grid only on screen freezes IE
Has anyone run into this problem.  I have a grid on a webpage and it will freeze IE 7.  IE will be taking up 97% of CPU time.  It seems to be locked into a loop of somesort.  I can get it to go away if I put a button at the top of the screen and it gets rendered correctly.  This first code will cause the problem:
 <%@ Page Language="VB" AutoEventWireup="false" CodeFile="wfCCUsers.aspx.vb" Inherits="Admin_wfCCUsers" %>
<%@ Register TagPrefix="igtbl" Namespace="Infragistics.WebUI.UltraWebGrid" Assembly="Infragistics35.WebUI.UltraWebGrid.v9.1, Version=9.1.20091.2055, Culture=neutral, PublicKeyToken=7dd5c3163f2cd0cb" %>
<%@ Register Src="UserControls/wcStandardAdminHeader.ascx" TagName="wcStandardAdminHeader"
    TagPrefix="uc1" %>
<!DOCTYPE html PUBLIC "-//W3C//DTD XHTML 1.0 Transitional//EN" "http://www.w3.org/TR/xhtml1/DTD/xhtml1-transitional.dtd">
<html xmlns="http://www.w3.org/1999/xhtml">
<head id="Head2" runat="server">
    <title>Console Documents</title>
    <script language="JavaScript" type="text/JavaScript" src="../ScriptFiles/SetWindow.js"></script>
    <script language="JavaScript" type="text/JavaScript">
        ResizeStandardWindow();
    </script>
</head>
<body background="../Images/AdminBackground.gif" onload="bodyOnLoadHandler()" onresize="bodyOnLoadHandler()">
    <form id="form2" runat="server">
    <asp:ScriptManager runat="server" ID="ScriptManager1">
    </asp:ScriptManager>
    <uc1:wcStandardAdminHeader ID="wcStandardAdminHeader1" runat="server" />
    <div align="center">
        <igtbl:UltraWebGrid ID="UltraWebGrid1" runat="server" Height="200px" Width="325px">
            <DisplayLayout AllowColSizingDefault="Free" AllowColumnMovingDefault="OnServer" AllowSortingDefault="OnClient"
                CellClickActionDefault="RowSelect" RowHeightDefault="20px" SelectTypeRowDefault="Extended"
                Version="4.00">
                <HeaderStyleDefault CssClass="HeaderStyle">
                </HeaderStyleDefault>
                <FrameStyle CssClass="FrameStyle">
                </FrameStyle>
                <SelectedRowStyleDefault CssClass="SelectedRowStyle">
                </SelectedRowStyleDefault>
                <RowAlternateStyleDefault CssClass="AlternateRowStyle">
                </RowAlternateStyleDefault>
                <RowStyleDefault CssClass="RowStyle">
                </RowStyleDefault>
            </DisplayLayout>
        </igtbl:UltraWebGrid>
    </div>
    </form>
</body>
</html>
But if I put in a button like so right after the FORM tag.  It renders without any problem.
 <asp:Button ID="Button1" runat="server" Text="Button" Width="1px" Height="1px" />
This only happens on Windows XP with IE 6 or 7.  I haven't tested 8 yet.  It runs fine on Windows 7 and IE 8 on my development machine.
