770
How to mix stacked area chart and line chart with 2 y axis
  I need to show stacked chart and line chart in single chart. Stacked area chart has very large value range on y axis and line series has vary low value range.
For example Im trying like below
 if(value<100)
 Infragistics.Silverlight.Chart.Series igLineSeries = new Infragistics.Silverlight.Chart.Series();
igLineSeries.ChartType =
ChartType.Line;
for (int lstCount = 0; lstCount < lstChartFinal[rowcnt].Count(); lstCount++)
  Infragistics.Silverlight.Chart.DataPoint igDatapoint = new Infragistics.Silverlight.Chart.DataPoint();
  igDatapoint.Value =
Convert.ToDouble(lstChartFinal[rowcnt].ToList()[lstCount].MyValue);
  igLineSeries.DataPoints.Add(igDatapoint);
//Adding y aixs in chart only once
if (intCountRatio == 0)
Axis yAxis = new Infragistics.Silverlight.Chart.Axis { AxisType =   AxisType.SecondaryY, Minimum  AutoRange = true };
igChart.Axes.Add(yAxis);
igChart.Series.Add(igLineSeries);
intCountRatio++;
//this is for stacked area chart
else
infragistics.Silverlight.Chart.
Series igSeries = new Infragistics.Silverlight.Chart.Series();
igSeries.ChartType =
ChartType.StackedArea;
ChartParameter chParamm = new ChartParameter();
igDatapoint.Value =
 igSeries.DataPoints.Add(igDatapoint);
//Adding y axis as primary only once
if (intCountAreaSeries == 0)
 Infragistics.Silverlight.Chart.Axis yAxis = new Infragistics.Silverlight.Chart.Axis { AxisType =   AxisType.PrimaryY, AutoRange = true };
  igChart.Series.Add(igSeries);
   intCountAreaSeries++;
here its showing 2 y axis..but showing same value range on primary y axis and secondary y axis.
First its plotting stacked area series and then line series. So i think y axis has autorange as true. so for secondary axis taking range of primary y axis.So not showing line series.
Please tell how to assign stacked series range for primary y axis and line series range for secondary y axis.
Also i have 2006,2007,2008 values on x axis.How to plot common x axis starting from 2006 not from zero.Should show 2006 instead of zero at start.
Please give modify code.Any help is appreciated
Thanks in advance,
Nandu
  • 1765
    Suggested Answer
    Hi Nandu,
    You can try the following code:
    This is in the MainPage.xaml.cs:
            public MainPage()
                InitializeComponent();
                Axis primXAxis = new Axis
                    AxisType = AxisType.PrimaryX,
                    Name = "PrimXAxis"
                Axis primYAxis = new Axis
                    Name = "PrimYAxis"
                Axis secondYAxis = new Axis
                    Name = "SecondYAxis",
                    Minimum = 2006,
                    Maximum = 9000,
                    Unit = 1000,
                    AutoRange = false
                theChart.Axes.Add(primXAxis);
                theChart.Axes.Add(primYAxis);
                theChart.Axes.Add(secondYAxis);
                Series stackedAreaSeries = new Series
                    ChartType = ChartType.StackedArea,
                    AxisX = "PrimXAxis",
                    AxisY = "PrimYAxis"
                Series lineSeries = new Series
                    StrokeThickness = 4,
                    ChartType = ChartType.Line,
                   AxisY = "SecondYAxis",
                stackedAreaSeries.DataPoints.Add(new DataPoint(5));
                stackedAreaSeries.DataPoints.Add(new DataPoint(6));
                stackedAreaSeries.DataPoints.Add(new DataPoint(8));
                lineSeries.DataPoints.Add(new DataPoint(2500));
                lineSeries.DataPoints.Add(new DataPoint(3000));
                lineSeries.DataPoints.Add(new DataPoint(4000));
                theChart.Series.Add(lineSeries);
                theChart.Series.Add(stackedAreaSeries);
    This is in the MainPage.xaml:
            <igChart:XamWebChart Width="400" Height="300" Name="theChart">
            </igChart:XamWebChart>
    Best regards,
    Anatoli Iliev
