Hello All,
While using Infragistics.Silverlight.XamWebHtmlViewer.v9.2.dll in the project throws following error.
Error 1 The "ValidateXaml" task failed unexpectedly.System.IO.FileNotFoundException: Could not load file or assembly 'Infragistics.Silverlight.v9.2, Version=9.2.20092.1007, Culture=neutral, PublicKeyToken=7dd5c3163f2cd0cb' or one of its dependencies. The system cannot find the file specified.File name: 'Infragistics.Silverlight.v9.2, Version=9.2.20092.1007, Culture=neutral, PublicKeyToken=7dd5c3163f2cd0cb' at System.ModuleHandle.ResolveType(Int32 typeToken, RuntimeTypeHandle* typeInstArgs, Int32 typeInstCount, RuntimeTypeHandle* methodInstArgs, Int32 methodInstCount) at System.ModuleHandle.ResolveTypeHandle(Int32 typeToken, RuntimeTypeHandle[] typeInstantiationContext, RuntimeTypeHandle[] methodInstantiationContext) at System.Reflection.Module.ResolveType(Int32 metadataToken, Type[] genericTypeArguments, Type[] genericMethodArguments) at System.Reflection.CustomAttribute.FilterCustomAttributeRecord(CustomAttributeRecord caRecord, MetadataImport scope, Assembly& lastAptcaOkAssembly, Module decoratedModule, MetadataToken decoratedToken, RuntimeType attributeFilterType, Boolean mustBeInheritable, Object[] attributes, IList derivedAttributes, RuntimeType& attributeType, RuntimeMethodHandle& ctor, Boolean& ctorHasParameters, Boolean& isVarArg) at System.Reflection.CustomAttribute.GetCustomAttributes(Module decoratedModule, Int32 decoratedMetadataToken, Int32 pcaCount, RuntimeType attributeFilterType, Boolean mustBeInheritable, IList derivedAttributes) at System.Reflection.CustomAttribute.GetCustomAttributes(Assembly assembly, RuntimeType caType) at System.Reflection.Assembly.GetCustomAttributes(Type attributeType, Boolean inherit) at System.Attribute.GetCustomAttributes(Assembly element, Type attributeType, Boolean inherit) at MS.Internal.Xaml.MS.Impl.XamlSystemBinding.AddPairsFromAssembly(XamlSchemaContext schemaContext, Assembly asm, String uri, List`1 pairs) at MS.Internal.Xaml.MS.Impl.XamlSystemBinding.SearchForXamlNamespace(XamlSchemaContext schemaContext, String uriString, IEnumerable`1 referenceAssemblies) at MS.Internal.Xaml.XamlSchemaContext.GetXamlNamespace(String xmlns, Assembly localAssembly) at MS.Internal.Xaml.XamlSchemaContext.GetXamlNamespace(String xmlns) at MS.MarkupCompiler.ValidationPass.ValidateXaml(String fileName, Assembly[] assemblies, Assembly callingAssembly, TaskLoggingHelper log, Boolean shouldThrow) at Microsoft.Silverlight.Build.Tasks.ValidateXaml.XamlValidator.Execute() at Microsoft.Silverlight.Build.Tasks.ValidateXaml.XamlValidator.Execute() at Microsoft.Silverlight.Build.Tasks.ValidateXaml.Execute() at Microsoft.Build.BuildEngine.TaskEngine.ExecuteInstantiatedTask(EngineProxy engineProxy, ItemBucket bucket, TaskExecutionMode howToExecuteTask, ITask task, Boolean& taskResult)WRN: Assembly binding logging is turned OFF.To enable assembly bind failure logging, set the registry value [HKLM\Software\Microsoft\Fusion!EnableLog] (DWORD) to 1.Note: There is some performance penalty associated with assembly bind failure logging.To turn this feature off, remove the registry value [HKLM\Software\Microsoft\Fusion!EnableLog]. DocManager
I have used following dlls in my project.
Infragistics.Silverlight.v9.2.dll and Infragistics.Silverlight.XamWebHtmlViewer.v9.2.dll
Any suggessions in this regard are appreciated..
Thanks in advance.
I was using those DLLs which are provided initially.
I have changed my DLLs and the problem is solved.
Thanks.
Ajay S. Nagnoor
Use both DLL's from same build 9.2, I think you are using one DLL of from trial version project.
Use both from full licensed project
Avinash
Hello Ajay,
Could you send us a sample project representing your case as a zip file.
Doychin Dochev
