Hi guys , it doesn't work when i apply customized style to Axis PrimaryY on XamWebChart , neither in xaml nor in the code behind .
in code :
Axis aY = _dataChart.Axes.FirstOrDefault<Axis>(axis => axis.AxisType == AxisType.PrimaryY); if (aY == null) { aY = new Axis { AxisType = AxisType.PrimaryY }; //it works when properties are set in this way /* aY.AutoRange = false; aY.Minimum = - 70; aY.Maximum = 100; aY.Unit = 10;*/ //it doesn't work when apply style to aY aY.Style = (Style)this.Resources["AxisStyle1"]; _dataChart.Axes.Add(aY); }
in Xaml:
<UserControl x:Class="ChartTest.LineChart" xmlns="http://schemas.microsoft.com/winfx/2006/xaml/presentation" xmlns:x="http://schemas.microsoft.com/winfx/2006/xaml" xmlns:igChart="clr-namespace:Infragistics.Silverlight.Chart;assembly=Infragistics.Silverlight.Chart.v9.2" Width="400" Height="300"> <UserControl.Resources> <Style x:Key="AxisStyle1" TargetType="igChart:Axis"> <Setter Property="AutoRange" Value="false"/> <Setter Property="Minimum" Value="-70"/> <Setter Property="Maximum" Value="100"/> <Setter Property="Unit" Value="10"/> <Setter Property="Background" Value="#58FFFFFF"/> </Style> </UserControl.Resources> <Grid x:Name="LayoutRoot" Background="White"> <igChart:XamWebChart x:Name="dataChart"> <igChart:XamWebChart.Axes> <igChart:Axis AxisType="PrimaryY" Style="{StaticResource AxisStyle1}"> <igChart:Axis.MajorGridline> <igChart:GridlineGroup Stroke="#00eaeaea" StrokeThickness=".5"> <!-- <igChart:GridlineGroup.GridlineStyle> <Style TargetType="igChart:GridlineGroup"> <Setter Property="Template"> <Setter.Value> <ControlTemplate TargetType="igChart:GridlineGroup"> <Grid></Grid> </ControlTemplate> </Setter.Value> </Setter> </Style> </igChart:GridlineGroup.GridlineStyle>--> </igChart:GridlineGroup> </igChart:Axis.MajorGridline> </igChart:Axis> </igChart:XamWebChart.Axes> <igChart:XamWebChart.Series> <igChart:Series ChartType="Line"> <igChart:Series.Marker> <igChart:Marker Type="Star5" MarkerSize="1.5" Fill="#3298F9" Foreground="#00C1F30B" LabelDistance="1" /> </igChart:Series.Marker> <igChart:Series.DataPoints> <igChart:DataPoint Label="Q1" Value="25" /> <igChart:DataPoint Label="Q2" Value="30" /> <igChart:DataPoint Label="Q3" Value="45" /> <igChart:DataPoint Label="Q4" Value="55"> <igChart:DataPoint.Marker> <igChart:Marker Format="{}{Value:c}"></igChart:Marker> </igChart:DataPoint.Marker> </igChart:DataPoint> </igChart:Series.DataPoints> </igChart:Series> <igChart:Series ChartType="Line"> <igChart:Series.DataPoints> <igChart:DataPoint Label="Q1" Value="10" /> <igChart:DataPoint Label="Q2" Value="-30" /> <igChart:DataPoint Label="Q3" Value="-20" /> <igChart:DataPoint Label="Q4" Value="25" /> </igChart:Series.DataPoints> </igChart:Series> <igChart:Series ChartType="Line"> <igChart:Series.DataPoints> <igChart:DataPoint Label="Q1" Value="25" /> <igChart:DataPoint Label="Q2" Value="30" /> <igChart:DataPoint Label="Q3" Value="45" /> <igChart:DataPoint Label="Q4" Value="60" /> </igChart:Series.DataPoints> </igChart:Series><!----> </igChart:XamWebChart.Series> </igChart:XamWebChart> </Grid></UserControl>
You can contact developer support for the status of any bug by providing the number. It looks as if this bug has not been marked resolved yet.
-Graham
It has been reolved in 2010 V1 or not
This is a bug in the chart control having to do with the precedence of some of these properties in the way they are set. I've submitted this as a bug: 25979. You can check on the status of this bug at any time by contacting Developer Support.
In the interim, if you set these properties directly in the xaml for the axis, rather than through the style, it should work appropriately.
