Please tell me how can i disable the default refresh image of Warp panel?
The WARP does not have property which disables indicator. However, it has options to customize its appearance. Reference to indicator is available only on client. So, you may process ClientSideEvent.InitializePanel, get reference to indicator, and set invisible content. Below is example:
<script type="text/javascript" id="igClientScript">function WARP1_InitializePanel(oPanel){ var pi = oPanel.getProgressIndicator(); pi.setTemplate('<span></span>'); //pi.setTemplate('<span style="display:none"></span>');}</script><igmisc:WebAsyncRefreshPanel ID="WARP1" runat="server" InitializePanel="WARP1_InitializePanel"> <asp:Button ID="Button2" runat="server" Text="Button" /></igmisc:WebAsyncRefreshPanel>
Hi!
I visited the link provided . there we have option of changing the default image of WARP.I was looking for the property,which allows me to make the image invisible.
The problem in my application is "Refresh interval is around 1 sec".WARP displays image continuously.I need to make the image visible false.
Check out the following link:
http://help.infragistics.com/NetAdvantage/ASPNET/2009.2/CLR3.5/
look under 'Client-Side Object Model (CSOM) Reference Guide'-> WebAsyncRefreshPanel CSOM -> WebAsyncRefreshPanel CSOM
There you will find information about the mentioned ProgressIndicator!!
Hope this helps.
