20
XamWebDateTimeRangeSlider doesnot update the minvalue
Hi
I am using the XamWebDateTimeRangeSlider and setting the min and max values of the slider dynamically.For some reason _slider.MinValue doesnot get updated (stores the previous value) with the recent value though I get the value at  minvalue.AddHours(-23) .I am posting my code can somebody please help me with that.
public
void SelectedValues(DateTime minvalue, DateTime maxvalue)
if
(minvalue == maxvalue)
_slider.MinValue = minvalue.AddHours(-23);
_slider.MaxValue = minvalue;
Infragistics.Silverlight.
FrequencyType type = (Infragistics.Silverlight.FrequencyType)Enum.Parse(typeof(Infragistics.Silverlight.FrequencyType), "Hours", true);
tickType = type;
foreach (DateTimeSliderTickMarks tick in _slider.TickMarks)
tick.FrequencyType = type;
xaml
Grid x:Name="LayoutRoot" Background
="White">
<m:Map Name
="map">
<Grid x:Name="_slidergrid" VerticalAlignment="Bottom" Margin="10,0,10,20" Height="40" HorizontalAlignment
="Stretch" >
<Rectangle Fill="{StaticResource ContainerBgBrush}" StrokeThickness="0" RadiusX="15" RadiusY="15" Grid.ColumnSpan="3" Effect="{StaticResource ShadowEffect
<Border BorderThickness="1,1,0,0" CornerRadius="15" BorderBrush="{StaticResource ContainerBorderBrush}" Grid.ColumnSpan
="3" />
<igSlider:XamWebDateTimeRangeSlider x:Name="_slider" VerticalAlignment="Center" Grid.ColumnSpan="3" HorizontalAlignment="Stretch" ThumbValueChanged
="_slider_ThumbValueChanged">
<igSlider:XamWebDateTimeRangeSlider.TickMarks
<igSlider:DateTimeSliderTickMarks IncludeSliderEnds="True" HorizontalTickMarksTemplate="{StaticResource HorizontalLabels
</igSlider:XamWebDateTimeRangeSlider.TickMarks
<igSlider:XamWebSliderDateTimeThumb IsSnapToTickEnabled="True" InteractionMode="Push" TrackFillBrush
="Transparent" />
<igSlider:XamWebSliderDateTimeThumb IsSnapToTickEnabled="True" InteractionMode="Push" TrackFillBrush="{StaticResource SliderTrackFill
</Grid>
DataTemplate x:Key="HorizontalLabels">
<StackPanel>
<Rectangle Width="2" Height="6" Fill="White" VerticalAlignment="Top" Margin="0,6,0,0"/>
<TextBlock x:Name="Labels" Loaded="TextBlock_Loaded" Tag="{Binding}" TextWrapping="NoWrap" Foreground="White" Margin="0,4,0,0"/>
</StackPanel>
</DataTemplate>
  • 4666
    Did you try with 10.2 version:
    The sample that i did works good:
        <Grid x:Name="LayoutRoot" Background="White">
            <Grid.RowDefinitions>
                <RowDefinition Height="170"/>
                <RowDefinition Height="30"/>
                <RowDefinition Height="70"/>
            </Grid.RowDefinitions>
            <Grid x:Name="CalendarGrid">
                <Grid.ColumnDefinitions>
                    <ColumnDefinition />
                    <ColumnDefinition/>
                </Grid.ColumnDefinitions>
                <basics:Calendar x:Name="startCalendar" SelectedDate="8/1/2010" HorizontalAlignment="Right"/>
                <basics:Calendar Grid.Column="1" x:Name="endCalendar" SelectedDate="8/4/2010" HorizontalAlignment="Right"/>
            </Grid>
            <Grid Grid.Row="1">
                    <ColumnDefinition/>
                    <ColumnDefinition/>
                    <ColumnDefinition/>
                    <ColumnDefinition/>
                <sdk:Label Content="Min:"/>
                <TextBox x:Name="TxtMin" Grid.Column="1" Text="{Binding MinValue, ElementName=_slider}" HorizontalAlignment="Stretch" VerticalAlignment="Stretch" />
                <sdk:Label Grid.Column="2" Content="Max:"/>
                <TextBox x:Name="TxtMax" Grid.Column="3" Text="{Binding MaxValue, ElementName=_slider}" HorizontalAlignment="Stretch" VerticalAlignment="Stretch" />
            </Grid>
            <Button Grid.Row="2" x:Name="BtnSetMinMax" Content="Set Min Max" Click="BtnSetMinMax_Click"/>
            <Grid x:Name="_slidergrid" Grid.Row="3" VerticalAlignment="Bottom" Margin="10,0,10,20" Height="40" HorizontalAlignment="Stretch" >
                <Rectangle StrokeThickness="0" Fill="Gray" RadiusX="15" RadiusY="15" Grid.ColumnSpan="3" />
                <Border BorderThickness="1,1,0,0" CornerRadius="15" BorderBrush="Red" Grid.ColumnSpan="3" />
                <igSlider:XamDateTimeRangeSlider MinValue="8/1/2010" MaxValue="8/4/2010" x:Name="_slider" VerticalAlignment="Center" Grid.ColumnSpan="3" HorizontalAlignment="Stretch" ThumbValueChanged ="_slider_ThumbValueChanged">
                    <igSlider:XamDateTimeRangeSlider.TickMarks>
                        <igSlider:DateTimeSliderTickMarks FrequencyType="Hours" TickMarksFrequency="4" IncludeSliderEnds="True"/>
                    </igSlider:XamDateTimeRangeSlider.TickMarks>
                </igSlider:XamDateTimeRangeSlider>
            </Grid>
        </Grid>
            private void BtnSetMinMax_Click(object sender, RoutedEventArgs e)
                if(startCalendar.SelectedDate == null || endCalendar.SelectedDate == null)
                    return;
                DateTime minvalue = (DateTime) startCalendar.SelectedDate;
                DateTime maxvalue = (DateTime) endCalendar.SelectedDate;
                DateTime minvalue1 = _slider.MinValue;
                DateTime maxvalue2 = _slider.MaxValue;
                if(minvalue == maxvalue)
                else
                    _slider.MinValue = minvalue;
                    _slider.MaxValue = maxvalue;
     Best!
    Mihail
