523
Set Tooltip Style on EventSpan/EventPoint
Can anyone provide with me an example of setting the tooltip style on an EventSpan/EventPoint or provide me with the default style for EventSpan/EventPoint.
  • 17605
    Verified Answer
    The default EventSpanTopStyle is:
                    <Style TargetType="local:EventSpan">
                        <Setter Property="Stroke" Value="{StaticResource BaseBorderBrush}"/>
                        <Setter Property="Fill" Value="{StaticResource BaseBorderBrush}"/>
                        <Setter Property="Template">
                            <Setter.Value>
                                <ControlTemplate TargetType="local:EventSpan">
                                    <Grid Margin="0,2,0,2">
                                        <Rectangle RadiusX="5"
                                                   RadiusY="5"
                                                   Fill="{TemplateBinding Fill}"
                                                   Stroke="{TemplateBinding Stroke}"
                                                   StrokeThickness="1"
                                                   Height="10"
                                                   VerticalAlignment="Top" />
                                    </Grid>
                                </ControlTemplate>
                            </Setter.Value>
                        </Setter>
                    </Style>
    The default EventSpanBottomStyle is:
                            <Setter.Value>
                                                   RadiusY="5"
                                                   StrokeThickness="1"
                                                   Height="10"
                                                   VerticalAlignment="Bottom" />
                                    </Grid>
                                </ControlTemplate>
                            </Setter.Value>
                        </Setter>
                    </Style>
    The default EventPointStyle is:
    <Style TargetType="local:EventPoint">
                        <Setter Property="Width" Value="10" />
                            <Setter.Value>
                                <ControlTemplate TargetType="local:EventPoint">
                                    <Grid Width="{TemplateBinding Width}" Height="{TemplateBinding Width}">
                                        <Ellipse Fill="{TemplateBinding Fill}" Stroke="{TemplateBinding Stroke}" StrokeThickness="1"/>
                                        <Ellipse Stroke="#66FFFFFF" Margin="1,1,1,1"/>
                                    </Grid>
                                </ControlTemplate>
                            </Setter.Value>
                        </Setter>
                    </Style>
    <LinearGradientBrush x:Key="BaseBorderBrush" StartPoint="0,0" EndPoint="0,1">
            <LinearGradientBrush.GradientStops>
                <GradientStopCollection>
                    <GradientStop Color="#FFa3aeb9" Offset="0"/>
                    <GradientStop Color="#FF8399a9" Offset="0.3700000047683716"/>
                    <GradientStop Color="#FF718597" Offset="0.3709999918937683"/>
                    <GradientStop Color="#FF617584" Offset="1"/>
                </GradientStopCollection>
            </LinearGradientBrush.GradientStops>
        </LinearGradientBrush>
