1253
combo box in hierarchy xamWebGrid
I tried to bind data to a combo box located in a child column layout.  At first, the grdStart will be displayed to the users.  When the user clicks on one of the row,  GridOrd will show some records. I'm using XamWebView also.  Here is the code behind:
 InitializeComponent();
 //Get data from WFC
 prxy.StartListCompleted += new EventHandler<StartListCompletedEventArgs>(prxy_StartListCompleted);
 prxy.StartListAsync();
        void prxy_StartListCompleted(object sender, StartListCompletedEventArgs e)
            (this.FindName("grdStart") as XamWebGrid).ItemsSource = e.Result;
            (this.FindName("grdStart") as XamWebGrid).Visibility = Visibility.Visible;
        private void grdStart_CellClicked(object sender, CellClickedEventArgs e)
            prxy.GetHeaderCompleted += new EventHandler<GetHeaderCompletedEventArgs>     (prxy_GetHeaderCompleted);
            prxy.GetHeaderAsync();
        void prxy_GetHeaderCompleted(object sender, GetHeaderCompletedEventArgs e)
            (this.FindName("grdOrd") as XamWebGrid).ItemsSource = e.Result;
            (this.FindName("grdOrd") as XamWebGrid).Visibility = Visibility.Visible;
            //Combo Box data
            prxy.GetCagegoryCompleted += new EventHandler<GetCagegoryCompletedEventArgs>(prxy_GetCagegoryCompleted);
            prxy.GetCagegoryAsync();
        void prxy_GetCagegoryCompleted(object sender, GetCagegoryCompletedEventArgs e)
             I  cannot find the combo box to set the ItemsSource!!!
     public class Category : EntityBase
             public string Id { get; set; }
             public string Desc { get; set; }
Here is Xaml code
    <Grid x:Name="LayoutRoot">
        <Grid.RowDefinitions>
            <RowDefinition Height="*"></RowDefinition>
        </Grid.RowDefinitions>
        <Grid.ColumnDefinitions>
            <ColumnDefinition Width="*"></ColumnDefinition>
        </Grid.ColumnDefinitions>
        <igTileView:XamWebTileView Name="TestView"  Width="auto" Height="auto" Grid.Column="0" Grid.Row="0">
            <igTileView:XamWebTileView.TilePanelSettings>
                <igTileView:TilePanelSettings MinimizedStripWidth="30" MinimizedStripLocation="Bottom">
                </igTileView:TilePanelSettings>
            </igTileView:XamWebTileView.TilePanelSettings>
            <igTileView:TilePane Name="Test1" Key="Test1"
                                 VerticalAlignment="Stretch" HorizontalAlignment="Stretch">
                <igTileView:TilePane.Header>
                    <TextBlock Text="Start" FontSize="14" FontWeight="Bold" />
                </igTileView:TilePane.Header>
                <Grid ShowGridLines="False" Height="auto" Width="auto">
                        <RowDefinition Height="*" />
                        <ColumnDefinition Width="auto" />
                    <igGrid:XamWebGrid Name="grdStart" ColumnLayoutAssigned="grdStart_ColumnLayoutAssigned" CellClicked="grdStart_CellClicked"
                                       Grid.Column="0" Grid.Row="0" BorderThickness="1" Background="LightGray"></igGrid:XamWebGrid>
                </Grid>
            </igTileView:TilePane>
            <igTileView:TilePane Name="Test2" IsEnabled="False"
                                 Height="auto" >
                    <TextBlock Text="Hello1" FontSize="14" FontWeight="Bold" />
                        <ColumnDefinition Width="*" />
                    <igGrid:XamWebGrid Name="grdOrd"
                        <igGrid:XamWebGrid.Columns>
                            <igGrid:ColumnLayout Key="OrdDet" HeaderVisibility="false" >
                                <igGrid:ColumnLayout.Columns>
                                    <igGrid:TemplateColumn Key="CatName" Width="120" HeaderText="Category"   HorizontalContentAlignment="Stretch">
                                        <igGrid:TemplateColumn.ItemTemplate>
                                            <DataTemplate>
                                                <TextBlock x:Name="CatDisplay" Text="{Binding Desc}" />
                                            </DataTemplate>
                                        </igGrid:TemplateColumn.ItemTemplate>
                                        <igGrid:TemplateColumn.EditorTemplate>
                                            <DataTemplate>
                                                <ComboBox x:Name="cmboCat" ItemsSource="{Binding}" Loaded="cmboCat_Loaded" />
                                            </DataTemplate>
                                        </igGrid:TemplateColumn.EditorTemplate>
                                    </igGrid:TemplateColumn>
                                </igGrid:ColumnLayout.Columns>
                            </igGrid:ColumnLayout>
                        </igGrid:XamWebGrid.Columns>
                        <igGrid:XamWebGrid.EditingSettings>
                            <igGrid:EditingSettings AllowEditing="Row" IsEnterKeyEditingEnabled="True" IsF2EditingEnabled="True" IsMouseActionEditingEnabled="SingleClick" IsOnCellActiveEditingEnabled="True" />
                        </igGrid:XamWebGrid.EditingSettings>
                </Grid>
        </igTileView:XamWebTileView>
    </Grid>
Please help!  Thanks!
