Hi.. i need to call a javascript function after the node is collapsed/expanded. Is there a way to do it?
ok..i will try that. Thanks for your assistance.
I'd suggest you as workaround to declare global variable and depends on your logic to change its value in NodeExpanded or NodeCollapse events in this way you will be able to track which node is expanded,or just to run another function with delay ( after node have been expanded ) . window.setTimeout("yourFFunction()").
Sorry, I've made a mistake with the control.
The CSOM for WebTree is here:
http://help.infragistics.com/Help/NetAdvantage/ASPNET/2009.2/CLR3.5/html/WebTree_Client_Side_Events_CSOM.html
but I am not able to see a such client-side event.
wait a minute.. those links you provided are for webgrid, isn't it? Can i use grid events in webtree? if so, please provide me a simple example.
ok.. but i am using Infragistics2.WebUI.UltraWebNavigator.v9.1.dll with framework2.0. I think these events are not supported in my version. I am getting Type 'Infragistics.WebUI.UltraWebNavigator.TreeClientSideEvents' does not have a public property named 'AfterRowExpanded' error. :(
