In Cell ExitingEditMode, just look at e.Cell.Row.Data.
You can then cast the Data property as the object your row represents, and do whatever calculations you need based on your properties.
-SteveZ
Hi ,
can you please send an example of Calculating CellValues of Selected Row.
I want to do row wise calculation after exiting a cell.(ie)CellExitingEditMode
I have populated the grid dynamically using reflection.
I am not able to find out other cell values of the selected row when I edit a single cell value of the selected row in CellExitingEditMode function.
Hi Amit,
In 9.2 we introduced Column Summaries. That does exactly this. You should take a look at this feature.
Hope this helps.
