Hi
Is there any other way to display maps other than using shape files and how to get the attribute name of the shape file ie (for using in data mapping)....
Its looking for the actual geometry data in that column. When I asked for the schema of the table I meant can you tell me all the column names and their SQL data types please? Have you tried just assigning each column name in the mapping until you get results?
The schema contains all the columns of the USA_adm2 shape file. I have doubt that what goes in the place of SpatialDataColumn. In that place i have put one the column name of the database(NAME_2).
<igMap:SqlShapeReader DataMapping="Data=SpatialDataColumn"/>I have put like this <igMap:SqlShapeReader DataMapping="Data=NAME_2"/>whether i have to bind all the columns of the databse or its enough to put only one column.Please make me clear what goes in the place of SpatialDataColumn and where the operation contract(GetData) will be called.-Oniv
igMap
SqlShapeReader
DataMapping
What does the schema of the USA_adm2 table look like? I get the feeling you are not matching the column name for the spatial data correctly. Have you put breakpoints in the service to make sure rows are being added to the list that is returned?
-Graham
i have gone throw the above link and tried that sample with USA_adm2 goespatial data which is converted from USA_adm2 shape file. but when i run the application the map is not displaying. I have one doubt that what goes in the place of SpatialDataColumn in the following code snippet.I red in web pages that column name of the Geo database(USA_adm2). when i put NAME_2 one of the column of USA_adm2 its not working.
<igMap:SqlShapeReader DataMapping="Data=SpatialDataColumn"/>whether i have bind all the columns of the database. i have attached the sample code. can you please check and reply....thanks in advance...
AH, almost forgot, you can also talk to a SQL database storing geometry infromation, see: http://help.infragistics.com/Help/NetAdvantage/DV/2009.2/CLR3.5/html/sl_dv_xamWebMap_Display_Geospatial_Data_from_SQL_Database_Server.html
