Are there any other {TemplateBinding xxxxxx} besides Title and Details that can be used to pass in data. Tried using Tag and Name but those both don't appear to keep the data even if I set them.
I am trying to put the following in the details style. I am using the Title to set the Image source and Details for the textblock, but need to pass in a 3rd piece of data for the link.
<Image Name="Image" HorizontalAlignment="Left" VerticalAlignment="Top" Source="{TemplateBinding Title}" Grid.Row="0"></Image><HyperlinkButton Name="hlAggregate" TargetName="_Blank" NagivationUri="{TemplateBinding ??????}"></HyperlinkButton><TextBlock Name="tbDetails" Grid.Row="1" MaxWidth="300" Text="{TemplateBinding Details}"></TextBlock>
Works great, thanks. This will solve alot of problems.
sorry, should have tested it first, thought that would work with a TemplateBinding, but I think the path is being interpreted as a attached property expression or something. Try something of this form instead.
{Binding Path=Details.Text, RelativeSource={RelativeSource TemplatedParent}}
-Graham
Hadn't thought of doing it that way, that would solve alot of problems if it worked. Currently {TemplateBinding Title} is actutally the image, not just the url. Tried creating a simple class with the two properties but something must be missing. Control renders but when the details tries to show it crashes.
see below answer
