55
Chart with Y2 axis shows columns on top of each other
I have a simple example chart to show the issue.  In a 2-series column chart, without using SecondaryY axis, the chart shows with the columns for each x axis data point next to each other, how we want it.  (see screenshot)  I have purposely set the values in the 2nd series to a different "range" than the 1st.
When adding the AxisY property to the 2nd series, the sencond Y axis shows properly, but the columns for each series are lined up on top of each other.
Am I using the Axis settings incorrectly, or is this the expected behaivor?  If so, is there any way to get the columns next to each other when using 2 Y axes?
Here's the XAML for the simple chart
<igChart:XamWebChart >
 <igChart:XamWebChart.Axes>
    <igChart:Axis AxisType="PrimaryY"  Name="y1" />
    <igChart:Axis AxisType="SecondaryY" Name="y2" />
  </igChart:XamWebChart.Axes>
 <igChart:XamWebChart.Series>
  <igChart:Series Label="North America" ChartType="Column" AxisY="y1" >
   <igChart:Series.DataPoints>
    <igChart:DataPoint Value="32500" Label="1st" />
    <igChart:DataPoint Value="54000" Label="2nd" />
    <igChart:DataPoint Value="39000" Label="3rd" />
    <igChart:DataPoint Value="44000" Label="4th" />
   </igChart:Series.DataPoints>
  </igChart:Series>
  <!-- remove AxisY property to see columns next to each other -->
  <igChart:Series Label="Europe" ChartType="Column" AxisY="y2" >
    <igChart:DataPoint Value="350" Label="1st" />
    <igChart:DataPoint Value="420" Label="2nd" />
    <igChart:DataPoint Value="450" Label="3rd" />
    <igChart:DataPoint Value="270" Label="4th" />
  </igChart:Series>
 </igChart:XamWebChart.Series>
