555
I follow the documentation to deploy an app, but I get this error
I hve followed the deployment guide to a hosted environment, but I get this error
Required permissions cannot be acquired.
Description: An unhandled exception occurred during the execution of the current web request. Please review the stack trace for more information about the error and where it originated in the code.
Exception Details: System.Security.Policy.PolicyException: Required permissions cannot be acquired.
Source Error:
An unhandled exception was generated during the execution of the current web request. Information regarding the origin and location of the exception can be identified using the exception stack trace below.
Stack Trace:
[PolicyException: Required permissions cannot be acquired.]
   System.Security.SecurityManager.ResolvePolicy(Evidence evidence, PermissionSet reqdPset, PermissionSet optPset, PermissionSet denyPset, PermissionSet& denied, Boolean checkExecutionPermission) +7604211
   System.Security.SecurityManager.ResolvePolicy(Evidence evidence, PermissionSet reqdPset, PermissionSet optPset, PermissionSet denyPset, PermissionSet& denied, Int32& securitySpecialFlags, Boolean checkExecutionPermission) +57
[FileLoadException: Could not load file or assembly 'Infragistics2.WebUI.UltraWebListbar.v9.2, Version=9.2.20092.1003, Culture=neutral, PublicKeyToken=7dd5c3163f2cd0cb' or one of its dependencies. Failed to grant minimum permission requests. (Exception from HRESULT: 0x80131417)]
   System.Reflection.Assembly._nLoad(AssemblyName fileName, String codeBase, Evidence assemblySecurity, Assembly locationHint, StackCrawlMark& stackMark, Boolean throwOnFileNotFound, Boolean forIntrospection) +0
   System.Reflection.Assembly.nLoad(AssemblyName fileName, String codeBase, Evidence assemblySecurity, Assembly locationHint, StackCrawlMark& stackMark, Boolean throwOnFileNotFound, Boolean forIntrospection) +43
   System.Reflection.Assembly.InternalLoad(AssemblyName assemblyRef, Evidence assemblySecurity, StackCrawlMark& stackMark, Boolean forIntrospection) +127
   System.Reflection.Assembly.InternalLoad(String assemblyString, Evidence assemblySecurity, StackCrawlMark& stackMark, Boolean forIntrospection) +142
   System.Reflection.Assembly.Load(String assemblyString) +28
   System.Web.Configuration.CompilationSection.LoadAssemblyHelper(String assemblyName, Boolean starDirective) +46
[ConfigurationErrorsException: Could not load file or assembly 'Infragistics2.WebUI.UltraWebListbar.v9.2, Version=9.2.20092.1003, Culture=neutral, PublicKeyToken=7dd5c3163f2cd0cb' or one of its dependencies. Failed to grant minimum permission requests. (Exception from HRESULT: 0x80131417)]
   System.Web.Configuration.CompilationSection.LoadAssemblyHelper(String assemblyName, Boolean starDirective) +613
   System.Web.Configuration.CompilationSection.LoadAllAssembliesFromAppDomainBinDirectory() +203
   System.Web.Configuration.CompilationSection.LoadAssembly(AssemblyInfo ai) +105
   System.Web.Compilation.BuildManager.GetReferencedAssemblies(CompilationSection compConfig) +178
   System.Web.Compilation.WebDirectoryBatchCompiler..ctor(VirtualDirectory vdir) +163
   System.Web.Compilation.BuildManager.BatchCompileWebDirectoryInternal(VirtualDirectory vdir, Boolean ignoreErrors) +53
   System.Web.Compilation.BuildManager.BatchCompileWebDirectory(VirtualDirectory vdir, VirtualPath virtualDir, Boolean ignoreErrors) +175
   System.Web.Compilation.BuildManager.CompileWebFile(VirtualPath virtualPath) +83
   System.Web.Compilation.BuildManager.GetVPathBuildResultInternal(VirtualPath virtualPath, Boolean noBuild, Boolean allowCrossApp, Boolean allowBuildInPrecompile) +261
   System.Web.Compilation.BuildManager.GetVPathBuildResultWithNoAssert(HttpContext context, VirtualPath virtualPath, Boolean noBuild, Boolean allowCrossApp, Boolean allowBuildInPrecompile) +101
   System.Web.Compilation.BuildManager.GetVirtualPathObjectFactory(VirtualPath virtualPath, HttpContext context, Boolean allowCrossApp, Boolean noAssert) +126
   System.Web.Compilation.BuildManager.CreateInstanceFromVirtualPath(VirtualPath virtualPath, Type requiredBaseType, HttpContext context, Boolean allowCrossApp, Boolean noAssert) +62
   System.Web.UI.PageHandlerFactory.GetHandlerHelper(HttpContext context, String requestType, VirtualPath virtualPath, String physicalPath) +33
   System.Web.UI.PageHandlerFactory.System.Web.IHttpHandlerFactory2.GetHandler(HttpContext context, String requestType, VirtualPath virtualPath, String physicalPath) +40
   System.Web.HttpApplication.MapHttpHandler(HttpContext context, String requestType, VirtualPath path, String pathTranslated, Boolean useAppConfig) +160
   System.Web.MapHandlerExecutionStep.System.Web.HttpApplication.IExecutionStep.Execute() +93
   System.Web.HttpApplication.ExecuteStep(IExecutionStep step, Boolean& completedSynchronously) +155
To wich permissions reffers the error?, I can not establish permissions in a web server, how can I fix this?
