was using ultrawebgrid 8.2 with no performance issues
upgraded to 9.2.20092.2056 and on IE6 and IE8 grouping cause IE to utilize 100% of CPU and take 2+ minutes to perform group even with < 20 rows.
Any suggestions or thoughts?
No performance issues on FireFox 3.6
Thank you Rado.
I have done so.
I appreciate your help.
Thanks for the sample. It really shows the issue. About Safari please keep in mind that the gird does not support it. Please refer here supported environments : http://ko.infragistics.com/support/supported-environments.aspx#SupportedEnvironments
Please can you create a support ticket and please refer this forum about the scrolling issue.
Thanks you!
I did try using width="100%" - this seems to be a valid work around.
However in safari, it give an infinitely expanding width horizontal scroll bar
But using a specified width in IE, it keeps expanding horizontally.
OK. Finally could recreate.
I have created a sample
http://63.170.253.111/default.aspx (default2.aspx has what it looks like in our app)
group by "student"
expand any row
If you are running IE < 8 or running in IE8 (in compatibility mode) your browser will hang
However
If you are running IE8 NOT IN COMPATIBILITY MODE, the grid will keep expanding horizontally - watch the scroll bar.
FireFox 3.6 seems OK, FireFox 3.57 seems OK
I used the grid as added from the toolbox - no edits to any properties EXCEPT removing height and width declaration.
Thank you for the response. Setting it up now.
