225
Stationary margins will resize the rows to fit the frame
I need to fix the header so I have set Stationary margins to "Header". That works just fine when I have several rows. The problem that I have now is that when the grid has only a few rows (say 2), it resizes the height of the rows to fit the grid which makes them look bad.
Which property should I change to allow the rows to have the default height and at the same time keep the header always visible?
  • 49378
    Suggested Answer
    Hi wnova,
    I know it has been some time since you asker your question, in case you are still in need of assistance I will be glad to help. This answer can also be useful to the other community members.
    In order for the rows to have a default height make sure that the RowHeightDefault property of the Grid's DisplayLayout is set to some value. This can be achieved through the Grid Designer.
    Please contact me if I you have further questions.
    Best Regards,
    Petar Ivanov
    Developer Support Engineer
    Infragistics, Inc.
