285
webnumericedit spin buttons rendering issue
Hi Support,
Below is how the webnumeric edit renders in IE7.
Here is the html code:
 <igtxt:WebNumericEdit ID="deligates" runat="server" CssClass="appNumeric" DataMode="Int"
                                        EnableAppStyling="True" HorizontalAlign="Left" MinValue="0" StyleSetName="Office2007Blue"
                                        Height="20px" Width="80px">
                                        <SpinButtons Display="OnRight" />
                                    </igtxt:WebNumericEdit>
Can you help please?
1st Consulting
  • 24497
    Suggested Answer
    I copied your codes to aspx in my test website and appeared correctly. However I do not have content of appNumeric.
    It is possible that page contains some settings which modify appearance of editor. If your page contains global css classes which affect TABLE, TR, TD, INPUT, IMG that it can be a problem. That can be padding, margin, font-size, line-height, etc. Try to test editors without those classes. Also parent html elements may affect appearance and if editors are located in initially invisible container, then it can be a reason as well.
    I suggest you test following:
    Add to your website a temporary aspx, copy there those codes directly into <form> and view page in browser. I expect that it will appear correctly.
    Next you may increase complexity of aspx by moving editors in containers which are used by your original application, add possible custom css classes (maybe links), etc.
    At some point on a particular "step" you will probably get your current appearance and you should figure out what causes issue.
