In an UltraWebGrid, I can have text data longer than the width of the column. I'm trying to wrap the text in order to have my cell on several lines. But when I run the project, my cell is on 1 line and the end of my text isn't visible...
I set Wrap in RowStyleDefault to true. I also tried with the MultiLine and Wrap proprieties in the CellStyle of the column.
My Version is 'NetAdvantage 2005 Volume3 CLR2'. I have not this problem In 'NetAdvantage 2005 Volume3 CLR1' version.
Did I miss something ?
Thanks in advance.
This is my source...
<igtbl:UltraWebGrid id="UltraWebGrid1" style="Z-INDEX: 100; LEFT: 8px; POSITION: absolute; TOP: 32px" runat="server" Height="504px" Width="384px" TabIndex="1"> <DisplayLayout JavaScriptFileName="../../Infragistics/Scripts/ig_WebGrid.js" StationaryMargins="Header" AllowSortingDefault="Yes" JavaScriptFileNameCommon="../../Infragistics/Scripts/ig_shared.js" RowHeightDefault="20px" RowSizingDefault="Free" Version="4.00" SelectTypeRowDefault="Single" HeaderClickActionDefault="SortMulti" BorderCollapseDefault="Separate" AllowColSizingDefault="Free" CellSpacingDefault="1" Name="grdxavailable" TableLayout="Fixed" CellClickActionDefault="RowSelect" NoDataMessage="" ColWidthDefault=""> <HeaderStyleDefault Cursor="Hand" VerticalAlign="Middle" Font-Size="9pt" ForeColor="#5B5B5B" BackColor="#DFE4FA" Height="20px"> <BorderDetails WidthLeft="0px" WidthTop="0px"></BorderDetails> </HeaderStyleDefault> <RowSelectorStyleDefault Font-Size="8pt" ForeColor="Silver"></RowSelectorStyleDefault> <FrameStyle Width="384px" Font-Size="9pt" BackColor="Gainsboro" Height="504px" Wrap="True"></FrameStyle> <FooterStyleDefault Cursor="Hand" VerticalAlign="Middle" BackColor="#DFE4FA"></FooterStyleDefault> <ActivationObject BorderWidth="0px" BorderColor=""></ActivationObject> <EditCellStyleDefault VerticalAlign="Middle" Font-Size="9pt" ForeColor="#5B5B5B"></EditCellStyleDefault> <SelectedRowStyleDefault Cursor="Hand" VerticalAlign="Middle" BackColor="#DFF4FA"></SelectedRowStyleDefault> <RowStyleDefault Cursor="Hand" VerticalAlign="Middle" Font-Size="9pt" ForeColor="#5B5B5B" BackColor="White" Height="20px" Wrap="True"></RowStyleDefault> <ImageUrls ImageDirectory="../../Infragistics/Images/"></ImageUrls> </DisplayLayout> <Bands> <igtbl:UltraGridBand> <AddNewRow View="NotSet" Visible="NotSet"></AddNewRow> </igtbl:UltraGridBand> </Bands></igtbl:UltraWebGrid>
I found out the reason. Because there is no space in the text.
Thank you !
I'm guessing here. I've never done what you are trying, but I've done the same thing with the header row before. If I remember right, it didn't work for the header until I manually set the header height to be tall enough to allow for the multiple lines. Maybe you've tried this, but if not it might be worth a shot.
Good luck!
