280
WebGrid Does not work with WebMask as Editor with InputMask
I want to use the mask input while editing the cell value that is why I have used the InputMask. I want following mask option should be available when I am in edit mode as well as after edit:
"___-__-___.____" using WebTextEdit alone not a part of Grid it is working fine, as I make this WebTextEdit as editor control it dose not work as expected. I have used the following code snippet at InitializeLayout event and simply take grid with webtextedit with double column for this:
this.UltraWebGrid1.Columns[2].Format = "###-##-###.####";
      WebMaskEdit1.InputMask = "###-##-###.####";
      this.UltraWebGrid1.Columns[2].EditorControlID = this.WebMaskEdit1.UniqueID;
        this.UltraWebGrid1.DisplayLayout.AllowAddNewDefault = Infragistics.WebUI.UltraWebGrid.AllowAddNew.Yes;
        this.UltraWebGrid1.DisplayLayout.AllowUpdateDefault = Infragistics.WebUI.UltraWebGrid.AllowUpdate.Yes;
It shows mask when I get out from edit mode but I want to show it while Editing the data. Please help me... I want to show mask in edit mode...
