805
Id Problems
First of all, you guys have done a great job with the Ribbon, I really like the style of it.
But I have some problems with using it.
When I clear the items of the Ribbon (XamWebRibbon.Tabs.Clear()) and want to readd a RibbonTab, which was previously in the collection of tabs, I'm getting an Exception like this:
Group with Id 'TabTitle1' already exists. Cannot add multiple group instances with the same Id.
It seems like that the Ribbon somehow saves the IDs of all Items, even after a Clear(), it can remember the IDs.
Second problem I have is that all the IDs must be unique in the Ribbon. Usually this make sense, but the ButtonTool has no Command or a Tag Property, so I have to save the name of a command in that Id Property to I know which command I have to execute on ButtonClick.
If I have 2 ButtonTools each in different Tabs referencing to the same command, than I get an Exception.
I'm not sure If I do something wrong or If this is an issue of the Ribbon.
Enrico
