Hi to All.......
My query is, I had a standard Panel named as Panel1 which contains an aspbutton... this panel1 is in
WebAsyncRefreshPanel. I want to hide the panel1 once the button was clicked. And i am using Infragistics7 and i dont want use upgrade version
help me urgently........
Regards
Nagaraju
Hi Nagaraju,
I assume that you want to hide your panel on server by Panel1.Visible=false. Below is example:
aspx:<igmisc:WebAsyncRefreshPanel ID="WARP1" runat="server"> <asp:Panel ID="Panel1" runat="server"> <asp:Button ID="Button2" runat="server" Text="Button" onclick="Button2_Click" /> </asp:Panel></igmisc:WebAsyncRefreshPanel>
aspx.cs:
protected void Button2_Click(object sender,EventArgs e){ this.Panel1.Visible = false;}
