365
Bind ContextMenu to columns of grid
I want to bind the columns of a grid to a contextmenu so I can change te visibility of the columns by a checkbox. On right click i want the ContextMenu to open and show a list of menuitems with checkboxes for each column. I want to do this in XAML.
I tried the following with no luck:
igMenu:ContextMenuService.Manager
<!--Set the attached Manager property to an instance of a ContextMenuManager object-->
<igMenu:ContextMenuManager OpenMode
="RightClick">
<!--Set the ContextMenuManager object's ContextMenu property to an instance of a xamWebContextMenu control-->
<igMenu:ContextMenuManager.ContextMenu
<igMenu:XamWebContextMenu ItemsSource="{Binding Source=xRelationGrid, Path
=Columns}">
<igMenu:XamWebContextMenu.ItemTemplate
<DataTemplate
<Grid
<CheckBox IsChecked="{Binding Path=Visibility,
Converter={StaticResource VisibilityToBool}}" Content="{Binding Path=Key}" />
</Grid>
</DataTemplate
</igMenu:XamWebContextMenu.ItemTemplate
</igMenu:ContextMenuManager.ContextMenu
</igMenu:ContextMenuService.Manager
Thanx,
Arjan
  • 3071
    Hi Arjan,
    You can do this in XAML but you need to inherit from XamWebContextMenu:
    public class GridContextMenu : XamWebContextMenu
      public static readonly DependencyProperty TheGridProperty =
        DependencyProperty
    .Register("TheGrid", typeof(XamWebGrid),
    typeof(GridContextMenu), new PropertyMetadata(null));
      public XamWebGrid TheGrid
        get{return (XamWebGrid)this.GetValue(GridContextMenu.TheGridProperty);}
        set{this.SetValue(GridContextMenu.TheGridProperty, value);}
      protected override void OnOpening(OpeningEventArgs args)
        this.TheGrid = this.PlacementTargetResolved as XamWebGrid;
        base.OnOpening(args);
    This sample shows how to use the GridContextMenu in XAML:
    <igGrid:XamWebGrid x:Name="TestGrid">
      <igMenu:ContextMenuService.Manager>
        <igMenu:ContextMenuManager>
          <igMenu:ContextMenuManager.ContextMenu>
            <l:GridContextMenu
              ItemsSource="{Binding RelativeSource={RelativeSource Self}, Path=TheGrid.Columns}">
              <l:GridContextMenu.DefaultItemsContainer>
                <DataTemplate>
                  <igMenu:XamWebMenuItem Header="{Binding}"
                        IsCheckable
    ="True"
    IsChecked="{Binding Path=Visibility, Converter={StaticResource VisibilityConverter}, Mode=TwoWay}">
                  </igMenu:XamWebMenuItem>
                </DataTemplate>
              </l:GridContextMenu.DefaultItemsContainer>
            </l:GridContextMenu>
          </igMenu:ContextMenuManager.ContextMenu>
        </igMenu:ContextMenuManager>
      </igMenu:ContextMenuService.Manager>
    igGrid:XamWebGrid>
    Marin
