115
add new row error
I have silverlight project using WCF and LINQtoSQL and xamwebgrid. following is the grid filling code:
VB CODE:
   Private Sub frmMasterFiles_Loaded(ByVal sender As Object, ByVal e As System.Windows.RoutedEventArgs) Handles Me.Loaded
        AddHandler webService.D_IngredientType_ListCompleted, AddressOf webService_D_IngredientType_ListCompleted
        webService.D_IngredientType_ListAsync()
    End Sub
    Private Sub webService_D_IngredientType_ListCompleted(ByVal sender As Object, ByVal e As ServiceReference1.D_IngredientType_ListCompletedEventArgs)
        Me.grdList.ItemsSource = e.Result
    End Sub
XAML CODE
        <igGrid:XamWebGrid Grid.Row="3"
                           HorizontalAlignment="Left"
                           Name="grdList"
                           VerticalAlignment="Top">
            <igGrid:XamWebGrid.AddNewRowSettings>
                <igGrid:AddNewRowSettings
         AllowAddNewRow="Both"
         IsEnterKeyEditingEnabled="True"
         IsF2EditingEnabled="True"
         IsMouseActionEditingEnabled="SingleClick"
         IsOnCellActiveEditingEnabled="True" />
            </igGrid:XamWebGrid.AddNewRowSettings>
            <igGrid:XamWebGrid.EditingSettings>
                <igGrid:EditingSettings
         AllowEditing="Row"
            </igGrid:XamWebGrid.EditingSettings>
        </igGrid:XamWebGrid>
when I insert new record into the add new row it gives following error
<System.NotSUpportedException:Collection was of a fixed size. at System.Array.Syste.Collection.IList.Add(Object Value)>
I am new to silverlight.
Please help me.
  • 9836
    This exception is usually caused by using an IList<> rather a type collection (e.g. List<>) as a return type of your method in the WCF service. If you can't resolve the issue, please paste some snippet on yor webservice class so I can try to duplicate the issue.
