90
XamWebGrid Column Header Freezes Browser on Click
Hi
My problem is simple and easy to repeat.  Whenever I click on a column header in my XamWebGrid control the application/silverlight/browser goes into an infinite loop and must be killed.  Everything else in the grid works fine, I can click my checkbox and they update the view model they are bound to.  I am not sure what is causing this so I have included all the relevant details below.
I have the following XamWebGrid template for which I am dynamically generating the columns based on other controls selected else where.
<infragistics_DG:XamWebGrid x:Name="ContentGrid"
                            AutoGenerateColumns="False"
                            Margin="{TemplateBinding Margin}"
                            MaxDepth="3"
                             DeleteKeyAction="None">
    <infragistics_DG:XamWebGrid.ColumnMovingSettings>
        <infragistics_DG:ColumnMovingSettings AllowColumnMoving="Disabled"/>
     </infragistics_DG:XamWebGrid.ColumnMovingSettings>
     <infragistics_DG:XamWebGrid.FilteringSettings>
         <infragistics_DG:FilteringSettings AllowFilterRow="None"/>
     </infragistics_DG:XamWebGrid.FilteringSettings>
     <infragistics_DG:XamWebGrid.ExpansionIndicatorSettings>
         <infragistics_DG:ExpansionIndicatorSettings>
             <infragistics_DG:ExpansionIndicatorSettings.Style>
                 <Style TargetType="igPrim:ExpansionIndicatorCellControl">
                     <Setter Property="Background" Value="Transparent"/>
                 </Style>
             </infragistics_DG:ExpansionIndicatorSettings.Style>
         </infragistics_DG:ExpansionIndicatorSettings>
    </infragistics_DG:XamWebGrid.ExpansionIndicatorSettings>
    <infragistics_DG:XamWebGrid.RowSelectorSettings>
        <infragistics_DG:RowSelectorSettings Visibility="Collapsed" EnableRowNumbering="False"/>
    </infragistics_DG:XamWebGrid.RowSelectorSettings>
    <infragistics_DG:XamWebGrid.AddNewRowSettings>
        <infragistics_DG:AddNewRowSettings AllowAddNewRow="None"/>
    </infragistics_DG:XamWebGrid.AddNewRowSettings>
    <infragistics_DG:XamWebGrid.EditingSettings>
        <infragistics_DG:EditingSettings AllowEditing="None" />
    </infragistics_DG:XamWebGrid.EditingSettings>
</infragistics_DG:XamWebGrid>
  the code for generating the columns is,
ColumnBaseCollection columns = grid.Columns;
columns.Clear();
var branchNameCol = new TextColumn();
branchNameCol.Key = "TradingBranchLegalEntityAgreement.LegalEntity.Name";
branchNameCol.HeaderText = "Branch Name";
columns.Add(branchNameCol);
var branchProductLookupConverter = new BranchProductDictionaryLookupConverter();
foreach (Product product in BranchProductTable.DisplayProducts)
    var productCol = new UnboundColumn();
    productCol.Key = product.Id;
    productCol.HeaderText = product.ShortName;
    productCol.ValueConverter = branchProductLookupConverter;
    productCol.ValueConverterParameter = product.Id;
    productCol.HorizontalContentAlignment = HorizontalAlignment.Center;
    productCol.HeaderStyle = new Style(typeof(HeaderCellControl));
    productCol.HeaderStyle.Setters.Add(new Setter(HorizontalContentAlignmentProperty, HorizontalAlignment.Center));
    productCol.HeaderTemplate = (DataTemplate)XamlReader.Load(
        string.Format(
                      @"<DataTemplate xmlns='http://schemas.microsoft.com/winfx/2006/xaml/presentation'
                           xmlns:layout='clr-namespace:System.Windows.Controls;assembly=System.Windows.Controls.Layout.Toolkit'>
                            <layout:LayoutTransformer>
                                <layout:LayoutTransformer.LayoutTransform>
                                    <RotateTransform Angle='-80'/>
                                </layout:LayoutTransformer.LayoutTransform>
                                <TextBlock Text='{0}'/>
                            </layout:LayoutTransformer>
                        </DataTemplate>",
                        product.ShortName.Replace("&", "&amp;")));
    productCol.ItemTemplate = (DataTemplate)XamlReader.Load(
                        @"<DataTemplate xmlns='http://schemas.microsoft.com/winfx/2006/xaml/presentation'>
                            <CheckBox IsChecked='{Binding Value.IsSelected, Mode=TwoWay}'/>
                        </DataTemplate>");
    columns.Add(productCol);
