Ok, here's what I need to know.
I have webgrid and a row edit template and I've set the row select to go into edit mode and that works great! However, due to design criteria I must provide an "edit" link for each row and have the row template pop up when that is clicked and ONLY that link.
Anybody know how I can do this?
thanks,
Scott
Hi Scottgrreenough
Can you please help me to get the solution for opening the row template if the column that contains Edit link
Many Thanks
Regards
Bhavani
ok, well I didn't do it that way exactly...I kinda cheated! :)
here's what I did. I check to see which column is clicked and then I only open the row template form if its the same column that contains my "edit" link.
Hope this helps someone!
You could build a javascript function that would call grid.BeginEdit (check the CSOM for the exact method name) when the link is clicked.
http://www.pageresource.com/jscript/jlinktut.htm
