Hi
I am using Infragistics controls 6.3.20063.53 in my ASP.NET 2.0 applications.
I am using UltraWebGrid inside a WARP.
<igmisc:WebAsyncRefreshPanel ID="WebRefreshPanel" runat="server" TriggerControlIDs="ImageButton1,MtDrop,cbActualOp,cbmax,cbRelease,btnReset" InitializePanel="WebRefreshPanel_InitializePanel"> <igtbl:UltraWebGrid ID="gridCriteria" runat="server" Width="700px" OnPreRender="gridCriteria_PreRender">
I am assigning datasource to grid on click on ImageButton1.gridCriteria.DataSource = this.RptDataSet;gridCriteria.DataBind();
function
WebRefreshPanel_InitializePanel(oPanel){oPanel.getProgressIndicator().setImageUrl("../Images/loading.gif");
It works fine when i return smaller datasets. But it does not work if i return large datasets.
The progress indicator is displayed and it does not disappear even after a long time.
Will this happen if an error occurs or Session expires after assigning the source to grid?
How to chek if the refresh is complete?
Is possible to identify the the start and end time of refresh?
Ashok
Hi I'm working on updating or converting infragistics controls to new version. so can some one help me to what can i replace WebAsyncRefreshPanel with in infragistics 20.1 . below one is the mark up I'm trying to convert to new version
<igtbl:WebAsyncRefreshPanel ID="warpGrid" runat="server" Height="99%" Width="100%" TriggerControlIDs="ResultPanel_btnSave" LinkedRefreshControlID="warpMessage" RefreshRequest="warpGrid_RefreshRequest" RefreshComplete="warpGrid_RefreshComplete" RefreshResponse="warpGrid_RefreshResponse" InitializePanel="warp_InitializePanel">
Thank you very much Viktor.
It worked. :)
Hi AniLex,
The WARP on client has few public methods including refresh(). Below is example to use it:
<script type="text/javascript">function refreshWARP(){ var warp = ig$('<%=WebAsyncRefreshPanel1.ClientID%>'); //var warp = ig_getWebControlById('<%=WebAsyncRefreshPanel1.ClientID%>'); warp.refresh();}</script>
<igmisc:WebAsyncRefreshPanel ID="WebAsyncRefreshPanel1" runat="server"> <asp:TextBox ID="TextBox1" runat="server"></asp:TextBox></igmisc:WebAsyncRefreshPanel><input id="refresh" type="button" value="button" onclick="refreshWARP()" />
How to refresh the WebAsyncRefreshPanel from javascript?
Hi Ashok,
If indicator is not stopped, then it means that response is not recieved: server failed to provide response on async postback, or response was not recognized by CallBackManager.
WARP raises on client several ClientSideEvents. If you know (on client) when your session was expired, then you may cancel ClientSideEvents.RefreshRequest and redirect. Below is example:
<script type="text/javascript"> var sessionExpired = false; function WARP1_RefreshRequest(oPanel, oEvent, id) { if(!sessionExpired) return; oEvent.cancel = true; window.location = 'http://google.com'; }</script><igmisc:WebAsyncRefreshPanel ID="WARP1" runat="server" RefreshRequest="WARP1_RefreshRequest"> <asp:Button ID="Button2" runat="server" Text="Button" /></igmisc:WebAsyncRefreshPanel>
