When I run the sample or my own application with the <GroupBySettings> section set as such:
<igGrid:XamWebGrid.GroupBySettings> <igGrid:GroupBySettings AllowGroupByArea="Top"/></igGrid:XamWebGrid.GroupBySettings>
When running the header displays the text "Drag a column header here to group by that column" as it should, but when you drag a column header up onto the text nothing happens. However, if you drag the columns underneath themselves, then they create the groups as expected. Any ideas?
Thanks in advance!
I was not able to reproduce the described behaviour. I've tested it on the latest service releases 9.1.2018, 9.2.2014 and the RTM 10.1.1005.
Could you provide more details or a sample?
Regards
