Sorry if this is documented somewhere but I wasn't able to find it in any of the examples or online forums or documentation.
Seems as though any child controls underneath the xamTileView/xamTilePanes arent getting initialized properly. For example:
<igTV:XamWebTileView x:Name="MainView" BorderBrush="{x:Null}" Background="{x:Null}" Foreground="{x:Null}" MaximizedStateChanging="XamWebTileView_MaximizedStateChanging" MaximizedStateChanged="XamWebTileView_MaximizedStateChanged">
<igTV:TilePane x:Name="SystemTile" Background="{x:Null}" BorderBrush="{x:Null}" Foreground="#FFF8F8F8" Header="System" BorderThickness="0" Style="{StaticResource sbxTilePaneStyle}" Margin="2,3,2,1" > <TextBlock x:Name="Test"></TextBlock> </igTV:TilePane> </igTV:XamWebTileView>
The textblock Test can't be found in the startup code which is called from pages InitializeComponent() function - the following function fails/returns null:
this.Test= ((System.Windows.Controls.TextBlock)(this.FindName("Test")));
Hi,There is a workaround. View this post at http://community.infragistics.com/forums/p/39051/222789.aspx#222789Regards,Marin
This is a known limitation with the Silverlight implementation - the variables that are automatically generated for the elements with x:Name in the content of TilePane have null value at runtime and there is no workaround for this.
Instead, you could use something like:
TextBlock textBlock = SystemTile.Content as TextBlock;
