180
AutoPage a grid
I would like to have paging on a XamWebGrid with the PageSize auto-calculated based on the height of the grid. Is there a easy way? Should I calculate the maximum number of rows that can be displayed and set the PageSize dynamically?
I tried to use grid.RowHeight, grid[0].ActualHeight, grid[0].Height, grid[0].HeightResolved without any success of getting the row height.
Thanks.
  • 5595
    This is a rather hacky solution, but it works. Try the following XAML / cs:
    igGrid:XamWebGrid x:Name="TestXamWebGrid" LayoutUpdated="TestXamWebGrid_LayoutUpdated"/>
    public partial class MainPage : UserControl
    // 1 for the Pager Row and
    // 1 for any partially visible row
    private const int MinPageSize = 2;
    public MainPage()
    this.Loaded += new RoutedEventHandler(MainPage_Loaded);
    InitializeComponent();
    void MainPage_Loaded(object sender, RoutedEventArgs e)
    ObservableCollection<ITestData> data = new ObservableCollection<ITestData>();
    for (int i = 0; i <= 10000; i++)
    data.Add(
    new TestData() { TextData = "data" + i });
    this.TestXamWebGrid.ItemsSource = data;
    private void DeterminePaging(XamWebGrid grid)
    int i = 0;
    while ((i < grid.Rows.Count) && (grid.Rows[i].Control != null))
    i++;
    if (i > MinPageSize)
    grid.PagerSettings.PageSize = i - MinPageSize;
    grid.PagerSettings.AllowPaging =
    PagingLocation.Bottom;
    private void TestXamWebGrid_LayoutUpdated(object sender, EventArgs e)
    XamWebGrid grid = this.TestXamWebGrid;
    grid.LayoutUpdated -=
    this.TestXamWebGrid_LayoutUpdated;
    this.DeterminePaging(grid);
    Note that this will depend on what exactly features you have enabled in the Grid and also will be performed once, initially - if you have resizing of the Grid, the page size will not change.
    HTH,
