Is there any way of knowing if the dialgog window is closed? I can't find a Closed event, so how do I know if my dialog window is being closed by the close button?
Thanks!
Excellent, thanks!
You can use the WindowsStateChanged event as described in this help article:http://help.infragistics.com/NetAdvantage/Silverlight/2010.1/CLR3.5/?page=SL_xamWebDialogWindow_Handle_Window_State_Changing_Events.html
After you handle the event, use the event arguments' property NewWindowState. It's an enumeration of type WindowState.When the dialog window is closed the state is chnaged to Hidden
Regards
