Hi
What I want to do is place a button or a hyperlink inside of each tile that is created when binding to the set of contact records queried from my database. The tiles are used in the search control which gives the user a simple summary of the contacts info. When this button/link inside of each tile is clicked I want to open up a far more comprehensive user control with a lot more info regarding the contact. How do I capture the click event of say a button inside a tile passing the event handler the ID of the contact that was clicked
Regards
Andrew
This seems to do the trick. But how can you get back to the parent TilePane object from here? Ideally, I'd like to set up my TileViewer like the Avee example where clicking anywhere in the TilePane will change the state. I can't figure out how to do that from just capturing the click event.
Hello Andrew,
I am just checking the progress of this issue and was wondering if you managed to overcome it or if you need any further assistance on the matter.
If the above suggestion helped you solve your issue please verify the thread as answered so other users may take better advantage of it.
Sincerely,
Petar Monov
Developer Support Engineer
Infragistics Bulgaria
www.infragistics.com/support
Hi Andrew,Look at this sample code:<ig:XamTileView ItemsSource="123456789"> <ig:XamTileView.TilePaneContentTemplate> <DataTemplate> <StackPanel> <TextBlock Text="{Binding}"/> <Button Content="More..." Click="MoreInfoClick"/> </StackPanel> </DataTemplate> </ig:XamTileView.TilePaneContentTemplate></ig:XamTileView>private void MoreInfoClick(object sender, RoutedEventArgs e){ System.Diagnostics.Debug.WriteLine((sender as Button).DataContext);}You can also display details in the maximized tile.Regards,Marin
