105
UltraWebMenu submenu hover problem
I have a web menu with a submenu. When I hover over the menu item that has the submenu the submenu hides behind the main menu. How to make the submenu appear over the main menu? Below is the code for the Webmenu I have:
       <igx:UltraWebMenuEx id="contextMenu" runat="server">
            <Levels>
                <ignav:level levelhoverclass="igmenu-LevelHover" levelclass="igmenu-LevelClass" index="0" levelcheckboxes="False"/>
                <ignav:level levelhoverclass="igmenu-LevelHover" levelclass="igmenu-LevelClass" index="1" levelcheckboxes="False"/>
            </Levels>
            <Items>
                <ignav:item tagstring="Add" text="Add"/>
                <ignav:item separator="True"/>
                <ignav:item tagstring="Recycle" text="Recycle"/>
                <ignav:item tagstring="Rename" text="Rename"/>
                <ignav:item tagstring="ShowDetails" text="Show Details">
                    <Items>
                        <ignav:item tagstring="Description" text="Description"/>
                        <ignav:item tagstring="Size" text="Size"/>
                        <ignav:item tagstring="None" text="None"/>
                    </Items>
                </ignav:item>
            </Items>
            <MenuClientSideEvents ItemClick="$Navigator.contextMenu_ItemClick" />
        </igx:UltraWebMenuEx>
  • 105
    Any help to solve this is appreciated. Thank you.
                <Levels>
                </Levels>
                <Items>
                        <Items>
                        </Items>
                    </ignav:item>
                </Items>
