By default, I get cell highlighting on MouseOver and cell selection on Click. I don't want either of those. When I click on any cell, I want the entire row selected and I don't want the RowSelector visible.
When the row is selected, I need to then call a command on the View's corresponding ViewModel using MVVM Light toolkit's EventToCommand.
Another option is to go with the more generic and pure delcarative approach which comes in handy in MVVM projects. Here's what I did... I really like it because it is very generic and I can reuse the same behavior on as many grids that use different collections.
Behavior:public class IgGridControlRowSelectedBehavior : Behavior<XamGrid> { protected override void OnAttached() { base.OnAttached(); if (AssociatedObject != null) AssociatedObject.SelectedRowsCollectionChanged += SelectedRowsCollectionChanged; }
protected override void OnDetaching() { if (AssociatedObject != null) AssociatedObject.SelectedRowsCollectionChanged -= SelectedRowsCollectionChanged; base.OnDetaching(); } void SelectedRowsCollectionChanged(object sender, SelectionCollectionChangedEventArgs<SelectedRowsCollection> e) { if (e.NewSelectedItems.Count == 1) {
// get reference to the selected row in the grid. var rowData = e.NewSelectedItems[0].Data;
// let anyone listening for a new selected item know it was selected if (rowData != null) Messenger.Default.Send(rowData, rowData.GetType()); } }}
Grid:<ig:XamGrid x:Name="CourseGrid" ItemsSource="{Binding Path=CourseCollectionViewSource.View}" AutoGenerateColumns="False"> <ig:XamGrid.SelectionSettings> <ig:SelectionSettings CellClickAction="SelectRow" /> </ig:XamGrid.SelectionSettings> <ig:XamGrid.Columns>[...]</ig:XamGrid.Columns> <i:Interaction.Behaviors> <myBehaviors:IgGridControlRowSelectedBehavior /> </i:Interaction.Behaviors></ig:XamGrid>
Where the namespace "i" = xmlns:i=http://schemas.microsoft.com/expression/2010/interactivity
View Model listening for selected items:Messenger.Default.Register<object>(this, typeof(Course), message => SelectedCourse = message as Course);
Those are all the settings you need.
Can you attach a sample of this behavior not working?
-SteveZ
I have the exact same values for the SelectionSettings. But, my XamGrid still doesn't seem to select the row. It's still recognizing cell selection. Are there any other properties in XamGrid that could override these attributes?
To answer your other question you can set the RowHover property on the grid to Cell, Row, or None, to stop the hovering effects.
In the grid, set the selection settings:
<igGrid:XamWebGrid.SelectionSettings> <igGrid:SelectionSettings CellSelection="None" CellClickAction="SelectRow" ColumnSelection="None" RowSelection="Single"/> </igGrid:XamWebGrid.SelectionSettings>
and handle the SelectedRowsCollectionChanged event:
SelectedRowsCollectionChanged="itemsSummaryGrid_SelectedRowsCollectionChanged"
private void itemsSummaryGrid_SelectedRowsCollectionChanged(object sender, SelectionCollectionChangedEventArgs<SelectedRowsCollection> e) { if (e.NewSelectedItems.Count == 1) { Messenger.Default.Send<ItemEntity>((ItemEntity)e.NewSelectedItems[0].Data); } }
Instead of RelayCommand in MVVM Light toolkit, I use Messenger to send the selected item.
