90
How to get the HeaderRow when there are no Rows
I have a requirement to display just the columns of my empty XamWebGrid and so am trying to write a unit test to iterate over the row header cells and assert column content template UI values.  I have seen the code below to get the , but unfortunately it requires you have at least one row before you can get to the XamWebGridRowsManager,
Row r = this.DataGrid1.Rows[0];
HeaderCellControl hcc = (HeaderCellControl)((RowsManager)r.Manager).
                                              HeaderRow.Cells["IsFavorite"].Control;
if (hcc != null)
    CheckBox headerCB = hcc.Content as CheckBox;
How can I get access to the RowsManager without any rows so I can navigate iterate over the rowheader column cells.
Thanks in advance
  • 40030
    Currenty, we've only exposed the RowsManager publicly off of our RowBase object.
    However, we do expose a RowsManager property off of the XamWebGrid, it's just protected.  So technically you could derive from the XamWebGrid, and expose the property yourself.
    public class MyGrid : XamWebGrid
             public XamWebGridRowsManager GridRowsManager
                  get{return this.RowsManager;}
    Hope this helps,
    -SteveZ
