For some reason one of our developers gets the following error messages when compiling under VS2008:
The property '_UnknownContent' does not exist on the type 'XamWebTileView' in the XML namespace 'clr-namespace:Infragistics.Silverlight.Controls;assembly=Infragistics.Silverlight.XamWebTileView.v10.1'.
The type 'XamWebTileView' does not support direct content.
Everybody else seems to work fine and we tried everything we could think of; clean/rebuild, removing and re-adding the reference, etc. Anybody have any ideas?
I just wanted to know if you was able to solve this error or you still need help? Just let me know. Thank you.
Sincerely,DimiDeveloper Support Engineer,MCPD Infragistics, Inc.
Hi,Is this happen with an empty TileView control? What about other developers?I found this topic: http://forums-silverlight-dit.neudesic.com/forums/p/22935/189083.aspx But I'm using the Microsoft Visual Studio 2008, Version 9.0.30729.1 SP, .NET Framework 3.5 SP1and I don't receive this error.Regards,Marin
