140
Force column generation in binding UltraWebGrid to empty table
Hi!
Is it possible to force the grid to generate columns even though the table has 0 rows?  I dropped a grid on an aspx page in the designer and after binding a dataset which has a table with 0 rows, the columsn do get generated (so the user can see that the report did run but dodn't generate any data).  Note: I have AutoGenerateColummns = true (in the designer).
 Then, as a test, on another page, I create a grid programmatically, using:
UltraWebGrid grid = new UltraWebGrid("UltraWebGrid1");
and set AutoGenerateCOlumns to true.
However, after:
grid.DataSource = ds.Tables[0];
grid.DataBind();
I get "Object not set (NullReference)" exception.
So, the question is: how is it that when created in the designer the grid does generate columns gracefully, but when created dynamically, the grid throws an exception on DataBind() ?
Thanks in advance!
S
