Hi There,
When I use the designer, which I actually like very much, often the markup does not get updated after closing it or clicking "Apply". If I then accidentally did changes in the markup the whole thing got completely out of sync. Why does the designer not update the markup immediately? Is there a way to avoid that problem? Is there a fix? Please help!
Kind Regards,LgtAppDev
Let me know if you have further questions related to this.
Regards,LyubaDeveloper Support EngineerInfragisticswww.infragistics.com/support
Is your grid inside some container? Update panel, tab or something similar? There is some problem with visual studio 2008, and when there is a grid control(webdatagrid, gridview) inside a container the properties doesn’t always get updated through the designer. Unfortunately I don’t know any way to avoid this. Luckily it seems that this issue doesn’t exist with the new visual studio 2010.
Lyuba Petrova
