Hi
I have a grid and a button outside of the grid. My grid has 3 columns - id, name, and comment - and it is bound to an ObservableCollection and the RaisePropertyChanged event updates the cells properly with the exception of the last cell. For instance, I have 3 records and if I enter the comment on all 3 records and I click the button, only the first 2 commentswere saved. But if I click on another cell, after I entered the comment on 3 records, then I can see all of them. How can I fix this issue? Thanks!
So your Data object never actually raises the property changed event.
You would need to do something like
public partial class Data : EntityBase {
private string _productName;
public string ProductName {get
{ return this._propertySTring; }
set{
if(value!=this._propertyString){
this._propertyString = value;
this.PropertyChangedHandler("PropertyString");
Thanks for the reply. Here is my code:
public string productName {get; set;} public string Comment{get; set;} }
public abstract class EntityBase : INotifyPropertyChanged { public event PropertyChangedEventHandler PropertyChanged; protected void PropertyChangedHandler( string propertyName) { if (PropertyChanged != null) PropertyChanged(this, new PropertyChangedEventArgs(propertyName)); } }
//button click event below
ObservableCollection<Data> selectData = new ObservableCollection<Data>();
var qry = from rec in selectData select rec;
foreach (var item in qry) {
MessageBox.Show(item.Comment); }
Could you provide some sample code that you are using?
Also, what is the purpose of the button, what does it do?
Anyone????
