Is it possible to drag - drop the rows in XamWebGrid.v10.1.
I want to drag and change the order of the rows. (Eg: Need to drag row3 to the position of row 5 and vice versa ).Is this supported? Can somebody point out an example.
rramapan
RIA support should be provided in XamGrid with 10.2, could you please confirm that you are using 10.2 build (1029)?
I was attempting to apply this to a project I have. I'm using 10.2 so I had to re-work it a little and it works fine in your test project. However in my project I use DomainDataSources and when I attempt to move rows using the following(from your project) there is an exception. I was wondering if you had any insight on how to get this working when RIA Services/DomainDataSources are involved?
tmpRow = (
Row)sourceCell.Cell.Row;
tmpRow.Delete();
grid.Rows.Insert(targetCell.Cell.Row.Index, tmpRow);
The exception is DataSourceDoesNotSupportIListException and it seems like it could possibly be related to this thread: http://blogs.infragistics.com/forums/t/30552.aspx
Please, find the attached in the attached file a sample for how you could achieve that.
You would need to retemplate the Grid as well as the CellControl.
HTH,
